Dual Mono DAC AK4490/AK4497
Old 10th June 2019, 11:33 PM   #411
Blade2019 is offline Blade2019
I must say that I'm not satisfied with dual ak4497 I bought.Unfortunately, usb input does not work as it should. I've tried with xmos and amanero card as well and it does not work( I must emphasize that both of those cards work with other dacs). Only things that actually work are optical and coaxialy- digital input
Old 11th June 2019, 03:55 AM   #412
ozcal is offline ozcal  Australia
Originally Posted by Bassivus View Post
I have tweaked this DAC AK4497 DAC DSD ??? ??384K DSD256 XMOS ????-???
Burson Op-amps in analog output, regs. etc. Now it is really good!
I am using some of his earlier boards in my dac and they appear to be very good. Also using Burson opamps.
Old 11th June 2019, 09:25 AM   #413
Bassivus is offline Bassivus  Serbia
Bassivus's Avatar
I went for finished dac simply because there was no DIY board with AK4497 chip from him available. I want also to change xtals in xmos for better. But it sound remarkable already. I also changed regs in digital part:
Old 19th November 2019, 12:03 PM   #414
unixdeveloper is offline unixdeveloper  United States
Hello, I am also having the same issue and USB doesn't work. Did you get any help from the seller? I assume the firmware is incorrect on the board or the design itself is buggy. The PCB inside is blue color.
If I get the interface diagrams, I can write my own software to control the DAC.
Subbu
Old 19th November 2019, 02:16 PM   #415
themystical is offline themystical  United Kingdom
I believe that the AK4497 requires a soft reset upon energisation before it becomes active, check data sheet. The Amanero etc. will need to be programmed to provide this reset?
Old 29th November 2019, 07:33 PM   #416
Hi,unixdeveloper
My PCB board is black.I got my money back.
This board:
2019 Dual AK4497EQ DAC AK4118 AK4497 DSD256 Native DAC 32Bit 384KHz USB AK4497 DAC,XMOS XU208 Amanero USB Bluetooth 5.0 APTX HD-in Amplifier from Consumer Electronics on AliExpress
Dual Mono DAC AK4490/AK4497Hide this!Advertise here!
Dual mono DAC and splitting DOR and DOL danils Digital Line Level 0 13th February 2014 04:37 PM
S.houBed DAC 132db Dual MONO pcm1794 xslavic Digital Source 30 24th February 2013 01:36 AM
ES9018 DUAL MONO DAC PCB syllable Vendor's Bazaar 7 15th September 2012 09:50 AM
Dac Help, WM8805 + CS8421 + Dual mono PCM1794 xslavic Digital Line Level 2 11th August 2012 05:25 PM
Dac or Dual-Mono Amps? Reference1042 The Lounge 2 9th March 2012 01:38 AM
Copyright ©1999-2019 diyAudio
