Non oversampling 2xPCM1702 feed by I2S experiment results
Old 25th March 2002, 10:36 PM   #11
Jocko Homo is offline Jocko Homo  United States
Banned
Ahem.......I believe you meant DF1702. TI no longer lists it. Looked the same, probably sounded the same.
Anyway.......all these newer filters have NO ultrasonic crap. Now look at the SAA7220.........UGH!
I suspect part of the reason is that it has a zero in the response to cancel out of the (3) poles in the analog section.
Jocko
Old 25th March 2002, 11:03 PM   #12
rfbrw is offline rfbrw
Jocko,
Two things.
What dac did you use with the DF1704? The other
thing is your preference for digital filters. Is it based on the belief that if the numbers are right the sound must be right and if you dont it like the too bad. Or is it down to listening ?
ray
ps. DF1700 => SM5813
Old 26th March 2002, 06:53 AM   #13
ergo is offline ergo  Estonia
Here is the interface schematic I used for I2S conversion
Ergo
Old 26th March 2002, 08:22 AM   #14
capslock is offline capslock  Europe
Default little flaw
Hi Ergo,
I believe there is one cosmetic flaw: the L and R signals will not appear at the outputs at the same time. Rather, there will be a skew of 23 microseconds. I doubt that this is audible, it corresponding to one speaker being advanced by 7 mm, but if it does not hurt my purist ear, at least it hurts my purist eye...
Greetings,
Eric
Old 26th March 2002, 08:34 AM   #15
tschrama is online now tschrama  Netherlands
Hi Ergo....
I hope you can help me out a bit... I just got myself a couple of PCM1702 chips.. I really really want to get more into digital design and was aiming for a zero oversampling DAC with the PCM1702 .. I'm not aiming for High End performance (yet) ... now what do I need besides the PCM1702?
Could you explain a bit or maybe give me a link to a Digital Audio introduction?
Thanks for this great thread! It is very informative stuff for me...
greetings,
Thijs
Old 26th March 2002, 08:38 AM   #16
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb I2S Philips format conversion to Sony/Burr-Brown
Hi All,
The Analog Drevices Application 207 note takes care of that using a dual D-type flip-flop and a quad NAND gate.
The two stereo channels separation is accomplished by the so called "stopped clock" technique i.e. the bitclock is stopped during loading the data to the DAC of one channel (don't remember which one). Both channels are latched simultaneuously as they share the same LATCH. No timing difference between left and right channel.
Unfortunately the Application Note is no longer on the AD website but I can send the PDF file by email if in need.
Old 26th March 2002, 09:00 AM   #17
Hi Elso Kwak,
I would very much like to read that application note. Could you send one to me?
Greetings,
Thijs (t.schrama@lumc.nl)
Old 26th March 2002, 11:45 AM   #18
Banned
rfbrw:
DF1700.........DF1702.......whatever. Getting too old to keep all these numbers in my head.
I used the DF1704 with the PCM1704.
My belief is based on listening (mine and others), and my spectrum analyzer.
Jocko
Old 26th March 2002, 06:49 PM   #19
Jocko,
I am sort of in the middle with this o/s no o/s debate as I am still not sure. The thing is the non o/s camp are no less adamant that they are right. Whatever,my way out is finish off my dac with a digital filter (NPC5843) that can be switched in and out of circuit.
Re: AN207
AN 207 IS available on the ADI website at http://www.analog.com/library/applic...udio/AN207.pdf
Alas AN207 will not work with the PCM1702 or PCM63 as is.
ray.
Old 26th March 2002, 06:55 PM   #20
Banned
No problem with being open-minded. I just can't see the point.
I personally don't like the sound of tubes, but I understand the appeal. I suspect the non-o/s crowd really doesn't like digital, which is fine. Then they should stick to vinyl and tubes, and we will all be happy.
See other posts today about slew-rate & op-amps in I/Vs. Might explain my adamant postion.
Jocko
Non oversampling 2xPCM1702 feed by I2S experiment resultsHide this!Advertise here!
So what does everyone feed their fullrangers with? Rick J. B. Full Range 159 27th December 2009 06:36 AM
Rock RSS feed? jman 31 Music 1 6th February 2009 08:58 PM
6AS7 Parallel Feed Amp lcsegeng Tubes / Valves 7 9th August 2008 02:17 AM
TDA5141 oversampling or non-oversampling ? Bernhard Digital Source 4 1st September 2004 10:27 AM
Parallel feed OT Bas Horneman Tubes / Valves 25 12th February 2003 02:07 PM
Copyright ©1999-2019 diyAudio
