Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#331 |
Hi.
@nautibuoy: very interested on your pcb/schematic. Is it ok now? I've got a jlsounds usb interface, double supply, etc. Now it's time to go DSD. In my system (only digital volume), popless playback is mandatory, so i'm very interested in a mute relay. EDIT: is this ok? http://jlsounds.com/uploads/LME49710_schematic.pdf Last edited by iperv; 9th September 2015 at 05:35 AM. |
#332 | |
I don't understand in any way this schematic. How the relay works? Is it an high pass filter? EDIT: ok, from right to left, not vice-versa ;-) Last edited by iperv; 9th September 2015 at 05:46 PM. |
#333 |
Has anyone found a unit that can output balanced DSD?
#334 | |
#335 |
Hi Vladimir, HiFiMeDIY has a USB to I2S device with balanced DSD output
HiFime UH1 384kHz USB DAC, headphone amplifier and I2S/DSD interface Attached is the pin out. Alternatively you can use a flip flop (74HC74) to create your own balanced output. I've posted my circuit before but here it is again. I use this daily, it works a treat. |
#336 |
That looks good. Is it sold just as a board that could be used with an isolator? Not sure if that is necessary, please advise
And is there a flip-flop board out there for sale? Last edited by vladimirb0b; 10th September 2015 at 04:49 AM. |
#337 |
Just a quick note to apologise to anyone waiting for an update on my filter board; stuff happens in life and I've had very little spare time to spend on this project and associated aspects and I have not resolved the mute relay issue.
Things have now moved on in this popular DSD subject area so I am not going to spend any more time on my project and instead will hook my wagon up to Acko's new project; Direct Drive DSD Cheers Ray |
#338 |
Thanks Ray.
#339 |
Hello everyone,
I have the JLsounds board and after reading the whole thread, I'm impatient to try this out. I suspect the passive output filter must be very well built to filter out the leftover MHzs of DSD. A resistor/inductor with very low parasitic capacitance and a capacitor with very low parasitic inductance, maybe tantalum type. A transformer is not enough IMHO. For now, I imagine a RLC LP filter with 16R , 30uH and 470nF. The R is there to damp the Q of the filter to ~0,5 |
#340 |
Dears ALL,
this is my personal version of Valve Preamplifier for DSD - DAC. In this special Preamplifier there only a capacitor of uncoupling among input and output. Is very important that all capacitors not polarized are of high quality. The polarized capacitors are long life and for use to 100Khz (for DCDC converter). Thanks and All the Best, JEDY |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board | bleachershane | Digital Line Level | 4 | 2nd February 2015 10:45 PM |
The DAC "do you have experience with this dac", Best diy dac for the money? | murphythecat8 | Construction Tips | 9 | 17th March 2014 08:30 AM |
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC –SUBBU DAC | grufti | Swap Meet | 0 | 26th November 2012 06:51 PM |
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! | sharpi31 | Digital Line Level | 2 | 10th January 2011 08:03 AM |
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? | TonyDasilva | Digital Line Level | 21 | 13th April 2009 06:10 PM |
New To Site? | Need Help? |
