The Best DAC is no DAC
Old 25th December 2018, 02:40 PM   #1881
francolargo is offline francolargo  United States
in essence, the 'noDAC' is nothing more than a powered isolator. I tried it and concluded that the main sticking point is sample rate. If the DSD rate is 256 or higher then the top-end filters can be less destructive. In the end, the sound was not sufficiently improved for me to put in the work to transition my atypical system. I remain interested in the cause for the sonic differences between PCM and DSD, and my working hypothesis is that some artifact of PCM is actually manifest at the level of driver cones. ...which is consistent with the range of reactions to the 'noDAC' method, as the properties of our speakers undoubtedly vary tremendously.
Old 25th December 2018, 04:03 PM   #1882
mcspack is offline mcspack  United States
Yeah in some systems DSD128 was the big improvement with some not noticing any big change between that and DSD256. Other systems swear by the improvements gained by shifting the noise into the higher spectrum. I'm sure some systems prefer PCM over a noDac. I think it depends on the implementation of the noDac or the DAC. I plan on copying hazard's latest noDac efforts. As far as isolation, I will be using twisted pear teleporters, which should handle that.
Old 30th December 2018, 09:27 PM   #1883
Presley is offline Presley
i am very interested in your idea, please post some photos if you will
Old 6th February 2019, 02:04 PM   #1884
Wondering if high quality, naked foil resistors, or exotic caps would make a difference in this noDac circuit? I mean we normally take great care with anything in the audio path. But is it necessary here? This is sort of a hybrid ana/digi, right?
Old 6th February 2019, 02:05 PM   #1885
Hey there Presley,
I'm getting closer to working on audio projects again, hope to have some photos for ya soon, next month or so maybe.
Old 6th February 2019, 02:14 PM   #1886
sumotan is offline sumotan  Indonesia
Anything affects the sound Mcspack its only a matter of whether its better or worse.
Lots of testing of parts involve though.
Old 7th February 2019, 06:24 PM   #1887
Hey there Presley,
GREAT NEWS! if you are successful I would love to buy a noDAC from you. or maybe you can post a step by step tutorial so i can do it myself? maybe you can make a new thread and the first page of it should be like a work in progress tutorial thats being updated
Old 9th February 2019, 05:50 PM   #1888
eimis is offline eimis  Europe
Originally Posted by erez1012 View Post
nice movie from 2010 that demonstrate DSD or one bit DAC with FPGA.
YouTube
that clearly demonstrates the multi Mhz spikes you feed straight into your amps...
Old 9th February 2019, 08:31 PM   #1889
MarcelvdG is offline MarcelvdG  Netherlands
I don't know what the latest circuit looks like, but assuming you are referring to a reconstruction filter: the reconstruction filter is completely analogue and handles the desired signal as well as a lot of high-frequency quantization noise. Having components with reasonable high-frequency performance (which implies reasonably small size and short or no leads) will be more important than in a "normal" audio circuit, everything else is just as critical or as uncritical as in a circuit that only handles the audio signal itself.
Old 4th March 2019, 10:17 AM   #1890
soko99 is offline soko99
whats your opinion about FiiO E10K USB DAC and Headphone Amplifier it has an excellent quality of sound, Lightweight design to fit in your palm with the affordable price also there are some list also available here The Best DAC of 2018
The Best DAC is no DACHide this!Advertise here!
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 09:45 PM
The DAC "do you have experience with this dac", Best diy dac for the money? murphythecat8 Construction Tips 9 17th March 2014 07:30 AM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC –SUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Copyright ©1999-2019 diyAudio
