Output stage for the Soekris R2R
Output stage for the Soekris R2R Please consider donating to help us continue to serve you.
Old 11th September 2016, 11:18 AM   #91
asanden is offline asanden  Netherlands
I use the raw output from both boards, however as the BPBP has two inputs I sometimes configure the boards as 'normal' instead of balanced and use the op-amp XLR dam output to compare two dams; i.e different filters or vref cap mod. (easy with DAM1021 rev3) or different versions flac/dsd of one song. I like that flexibility.
For the moment I only use my 600 ohm headphones direct on the BPBP output, I am building a balanced amp this fall.
Old 13th September 2016, 08:27 PM   #92
Delete is offline Delete  United States
Unfortunately I don't see any specs regarding gain in his writeup. I see there's a buffer stage, then the diff amp stage with variable gain, do you happen to know the gain spec? Sorry for all the questions, but I appreciate the answers.
I'd like to have both SE and balanced outs. But being indecisive, and not too knowledgable is hindering my process.
Old 13th September 2016, 09:33 PM   #93
The gain is from unity to infinite, that's is the fallback of the BPBP design, i.e. if you break the pot connections the gain raises to max, and may blow your speakers.
I use a ladder BPBP add-on by Hans Polak which limits the gain to 1 or 2 or whatever you like by selecting a resistor value. The bare small I2C SMD PCB is supplied by TviCol, who does the Maya preamps. See group-buy and digital line forums. Hans also designed a input selector switch PCB as another BPBP add-on. I use ladder/switch PCB's and not the Maya controleer, I write my own Arduino code.
I don't mix SE and balanced in one case, I have a separate SE DAC.
Old 15th September 2016, 03:02 AM   #94
I will look into them,thanks! Considering the amount of research I still have left for this stage, I'm going to use the buffered outs until I make up my mind. I'm doing more reading and less building.
Old 2nd December 2016, 09:22 PM   #95
adeveza is offline adeveza  United States
I just finished my Soerkis Dac and SDTrans384. I just got it wired just to test, however, I tested all voltages and it seems ok, the Dac locks on to the signal, but there is absolutely no sound, I could not figure it out, can someone help me please? I got the power, the I2s signal from my SDTrans, got the volume all the way up, hooked up the raw signal to my amp, and nothing??...HELP!!
Alex
Old 3rd December 2016, 05:54 AM   #96
kumori is offline kumori  Europe
Alex
This is probably the wrong thread, because it has nothing to do with an output stage. Can you test the SDtrans and the soekris independently? With another I2S DAC and another I2S source?
Old 4th December 2016, 03:36 PM   #97
Thanks for the reply. I was able to figure it out, I just panicked, but thanks anyway.
Old 6th January 2017, 08:47 PM   #98
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Any advantage to using this buffer for an output stage for the Soekris?
See schematic in first post.
B1 Rev. 2
I build, therefore I am.
Do not create problems where there are none.
Old 8th January 2017, 01:27 AM   #99
TioFrancotirador is offline TioFrancotirador  Poland
B1 Rev. 2
I have tried Salas DCB1, but it did not bring any improvement in my case. I do however have Vrefs powered with external regs, maybe that is why.
Based on my experience the best output stage for Soekris is no output stage at all since it does not required one. The best combo I got so far is connecting raw outputs (skipping onboard opamps) directly to Modulus 86 amplifier.
Old 8th January 2017, 03:19 AM   #100
vdi_nenna's Avatar
Thanks Tio.
Output stage for the Soekris R2RHide this!Advertise here!
Filter brewing for the Soekris R2R spzzzzkt Digital Line Level 1856 9th January 2020 11:24 PM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 08:23 AM
what happens if the voltage of the output stage exceeds the VAS Stage in LME amps rhythmsandy Solid State 0 13th October 2013 07:03 PM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 10:05 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
