Filter brewing for the Soekris R2R
Old 27th June 2019, 11:35 AM   #1781
Blitz is offline Blitz  Germany
I am using 1.21, Spikestabber's package and DAM1941. No issues here.
Is it hard to assemble a Package with different NOS filters only ? Currently I like the NOS filter best.
Old 28th June 2019, 08:51 AM   #1782
boxerfan88 is offline boxerfan88
Default Filter brewing for the Soekris R2R
i noticed there is a 1.23 firmware in the dam1941 folder. is it compatible with the dac1541?
i also noticed the 1.21 firmware in the dac1541 folder. is there a changelog showing the differences between 1.21 vs. 1.20?
Old 16th July 2019, 08:56 PM   #1783
mocenigo is offline mocenigo  Germany
Where? The 1.21 for the 1541?
Old 18th July 2019, 08:24 PM   #1784
Seenc is offline Seenc
Do any of you know whether the spikestabber’s package will work with 1121?
Old 18th July 2019, 10:53 PM   #1785
dewdrop is offline dewdrop
I tried to use the Raspberry Pi to the DAM 1121 to upload the filters using minicom as described by tonno in the DAM 1941 thread however, I do not seem to see any success in it. I definitely connected the serial lines and I2S and disabled the shell and enabled serial.
RPI DAM1121
6 GND --------- GND (one of them on J2)
8 TXD --------- COM_RXD 10 (J2)
10 RXD --------- COM_TXD 12 (J2)
12 BCK --------- I2S_2_BCLK 6 (J3)
35 LRCK --------- I2S_2_LRCLK 4 (J3)
40 DOUT --------- I2S_2_DAT 2 (J3)
As a test, I tried to switch inputs, i.e. I4 or I5. Any other checks that i can do?
Thanks in advance!
Ed
Old 19th August 2019, 08:57 PM   #1786
wushuliu is offline wushuliu  United States
wushuliu's Avatar
Just leaving these reminders for any future searches regarding Filter brewing as it can be extraordinarily confusing to to figure out the process:
1. There's lot of mentions about upgrading firmware, but I only found 1 post instructing that uManager also needs to be updated! Maybe it's instructed somewhere obvious but I didn't see it. I couldn't get my DAM to play after the firmware 1.21 and thankfully found a post mentioning that uManager needs to be updated as well after the FW by just typing (#)'update' in uManager and hitting enter.
2. If anyone wants to see the *current* filters selected for the DAM, type (#)'filters' in uManager.
And a reminder regarding Play Mode to demo filters courtesy of Vdi_nenna:
when you are in umanager by hitting +++, you are not in play mode . By simply connecting to the soekris terminal, your computer is communicating with the dac. Play mode works from just connecting to the dac with a terminal, such as extraputty...
Connecting to the terminal (and not umanager) you can type F4 for linear, F5 for mixed, F6 for minimum or F7 for soft. Not function keys, but actual letters and numbers. Use caps lower case didn't work for me. Play mode is not saved if the dac is power cycled.
3. Type '?' for Help in uManager. You will see the list of commands to find the entire/all of filter list, lower/reduce/turn down volume etc.
Old 20th August 2019, 06:56 AM   #1787
wushuliu's Avatar
After comparing different filters I've settled on TNT's 44 for now. I could live with any of the filters but the TNT so far does have a 'live, in the room' quality to it. A little more dynamic range, maybe? Or a very slight loudness effect? I dunno but guitars do crunch real good with it and operatic vocals have real presence without being harsh. This is via PC/USB/I2S/1021/headamp/HD6XX headphones
Old 20th August 2019, 07:28 AM   #1788
TNT is offline TNT  Sweden
Glad you like it! One more win for science over woodo as there is nothing but adherence to the sampling theorem in this filter. No "fourier denial" what so ever
More distortion to the people!
Old 20th August 2019, 07:46 AM   #1789
Darn, everyone's in the party and I can't get mine to communicate.
Ed
Old 20th August 2019, 10:47 AM   #1790
Probably the wrong version/type dongle... there are two diffeerent voltage levels... 3,3 and 5.... check the manual.
Filter brewing for the Soekris R2RHide this!Advertise here!
Soekris' DAC implementations Eldam Digital Line Level 1129 28th July 2019 11:21 PM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 07:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 09:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 12:29 PM
Copyright ©1999-2019 diyAudio
