Filter brewing for the Soekris R2R
Old 18th April 2019, 10:27 AM   #1751
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Is there any discussion/explanation on what the DC filter does and in what way it is audible? I must have missed this.
Old 8th May 2019, 04:16 PM   #1752
Nanekiu is offline Nanekiu  Norway
How does the DSD decimation filter actully work, at what rate does it decimate the DSD stream, is it to 8x 44/48khz, or does it decimate to 2.8/3.1mhz.
Old 8th May 2019, 08:46 PM   #1753
SebastianL is offline SebastianL  Denmark
Originally Posted by SebastianL View Post
@TNT: Johan could you please upload the latest filter pack including your great filter in F4, but with the DC Blocking ACTIVATED? If I had the txt file I could change it myself and compile a skr file, but I understand you're not willing to publicize the txt file atm.
I'm asking this favour because lately my amp has been blowing fuses and popping tubes and I'd like to be on the safe side.
Sadly my amp has been popping a few more output tubes and blowing fuses even with the DC blocking in place. So now I'm certain it's caused by a pack of bad EL34 tubes (by German TAD) with no more than 200 hours on them. Good quality tubes are hard to come by these days.
I'm concluding that omitting the DC blocking is doing no harm, at least in my system.
Old 9th May 2019, 08:36 AM   #1754
Pigeatgarlic is offline Pigeatgarlic  Viet Nam
Hi all,
Now we living in 2019 and can you tell me which power supply is the most complete/best for the soekris board and rasberry pi3+ ian’reclocker i2s combo, i know this power supply dont need too much power but must have lowest dítortion. Thus, in theoretical, battery do well with low cost, why nobody use it
Old 9th May 2019, 03:59 PM   #1755
OK so i found the answer to my own question regarding the DSD decimation, someone said that it decimates to 352/384khz rates and FIR2 upsamples it to 2.8/3.1mhz again.
Soekris just wondering but is it technically possible to decimate the DSD128/256 stream directly to FIR2 rates, i'm curious if that will have a effect on SQ.
Old 9th May 2019, 07:02 PM   #1756
@TNT can you please upload your Filter with 1015_Kb16_BW replacing C128dp, I'm really liking the sound of that filter.
I've attached the text file but i think gain needs to be changed for it to not clip with 1.19+ firmware.
Originally Posted by Pigeatgarlic View Post
Hi all,
The salas 1.3 Group buy found on diyaudio would be a very good place to start for a psu.
Old 11th May 2019, 08:01 AM   #1757
TNT is offline TNT  Sweden
Sorry but there are som many variants that could be made so I will not start on that rocky road. It is a direct contender at 44,1 so I think one should be able to make a permanent choice.
More distortion to the people!
Old 12th May 2019, 06:40 PM   #1758
Arunas B is offline Arunas B  Lithuania
Hi all,
I use two 12v batterys with no problem. 7ah on negative rail and 9ah on positive it give good 3days without charge.
Old 22nd May 2019, 03:33 PM   #1759
Lawrenceho is offline Lawrenceho  Hong Kong
Hi all,
Do we have a NOS filter that works with DAM1021 firmware 1.06?
I am aware that one can modify the stock F6 (minimum) filter using tools provided by Soren. However, all NOS filters I found are in .skr not .txt.
Any help would be much appreciated!
Lawrence
Old 27th May 2019, 03:34 AM   #1760
Originally Posted by Lawrenceho View Post
Hi all,
Lawrence
There's a nos filter in page 170 in the filter pack listed there.
BTW has anyone compared which FIR2 filters sounds the best?
Filter brewing for the Soekris R2RHide this!Advertise here!
Soekris' DAC implementations Eldam Digital Line Level 1129 28th July 2019 11:21 PM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 07:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 09:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 12:29 PM
Copyright ©1999-2019 diyAudio
