Filter brewing for the Soekris R2R
Old 10th April 2019, 10:11 AM   #1741
TNT is offline TNT  Sweden
Is it just to add yet an other set?
More distortion to the people!
Old 10th April 2019, 10:12 AM   #1742
soekris is offline soekris  Denmark
Originally Posted by TNT View Post
Aha - didn't know that. Probably Sören has an explanation.
Filters should be designed with same gain.
Sĝren
Old 10th April 2019, 01:04 PM   #1743
Nanekiu is offline Nanekiu  Norway
Same filter was flashed between 1.15/1.20+.firmware but the volume still is less on the red filter slot.on 1.15.i would expect them to have the same.volume as the gain is the same, unless you
changed the internal values in the firmware for digital volume in later versions?
Old 10th April 2019, 09:32 PM   #1744
Update: Reflashing firmware fixed it.
Old 11th April 2019, 09:08 PM   #1745
The "1021filt_105.txt"... what was this? Short, shallow? And came after 099 which was technically much better? Why? Just want to know the story
Old 12th April 2019, 09:29 AM   #1746
Sören, please explain how "shared filter" work. When I generate a filter in rePhase I'm asked for a rate. How does one and the same filter work for different rates?
Old 18th April 2019, 01:10 AM   #1747
SebastianL is offline SebastianL  Denmark
@TNT: Johan could you please upload the latest filter pack including your great filter in F4, but with the DC Blocking ACTIVATED? If I had the txt file I could change it myself and compile a skr file, but I understand you're not willing to publicize the txt file atm.
I'm asking this favour because lately my amp has been blowing fuses and popping tubes and I'd like to be on the safe side.
Old 18th April 2019, 07:17 AM   #1748
OK!
Added:
-- DC Blocking -3db @ 2 hz, 1st order, 352.8K/384K Samplerate
dam1021,352800,8,29,5,1
29 DC Blocking IIR, 352.8 Ksps, 2 Hz HP 1st order
1.00
-1.00
0.00
0.99996438167
-0.00
dam1021,384000,8,29,5,1
29 DC Blocking IIR, 384 Ksps, 2 Hz HP 1st order
1.00
-1.00
0.00
0.99996727561
-0.00
to the last published file.
Old 18th April 2019, 07:20 AM   #1749
It would be interesting to know if your fuse problems goes away. Also to know which files causes it.
Old 18th April 2019, 10:23 AM   #1750
Wow, wicked fast response TNT!
I'll give it a go and see what happens. Of course I'm not sure the omitted DC blocking is causing the fuses to blow.
Thanks a lot.
Filter brewing for the Soekris R2RHide this!Advertise here!
Soekris' DAC implementations Eldam Digital Line Level 1129 28th July 2019 11:21 PM
Sold: Soekris DAM1021 R2R DAC Eldam Swap Meet 6 6th February 2015 07:23 AM
24-bit R2R DAC using miltiple 16/18/20-bit R2R chips Marek Digital Source 21 1st April 2011 09:05 PM
project brewing in my head, challenging, but seem like a good way to try new concepts lemans23 Multi-Way 26 11th October 2005 12:29 PM
Copyright ©1999-2019 diyAudio
