Soekris' DAC implementations
Old 27th December 2018, 02:43 PM   #1111
Dimdim is offline Dimdim  Greece
It's safe to assume that the Amanero has plated-through holes (I assume that is what you meant be tin-plated). If you do not have a lot of experience with removing such parts definitely go with the removal of the ferrite and capacitor.
http://www.dimdim.gr
Old 27th December 2018, 02:52 PM   #1112
ynmichael is offline ynmichael
Thanks for the advice! I'll report back next week once I get the parts
Old 11th January 2019, 05:35 AM   #1113
Just realized that I promised to reply back. 5V mod worked well. More details in the main dam1021 thread
Old 16th July 2019, 07:41 PM   #1114
transcendent is offline transcendent
Looking for some clarification on I2S input connections for Soekris 1021. Planning to use it with XMOS 384kHz DXD DSD256 high-quality USB to I2S/DSD/SPDIF PCB - DIYINHK
Using separate PSU with 5VDC for USB to I2S interface. Is it OK to just connect directly from DIYINHK board 3.3V connections to DAC ISO 3.3V J3?
Old 19th July 2019, 05:17 PM   #1115
tods is offline tods  Germany
Follow the User guide:1. External regulated 3.3V power supply is connected to the 20pin header pins label 3.3vINx2
So no 5V PSU, try 3.3V and also use the 3.3V for DAC ISO 3.3V J3
Torsten
Old 20th July 2019, 08:48 AM   #1116
Torsten
Thanks Torsten ! I guess my question was if I can re-use same 3.3V PSU for both XMOS module and DAC?
Old 20th July 2019, 10:35 PM   #1117
hirscwi is online now hirscwi  United States
Default dam1021 i mono mode?
Greetings,
Can this DAC be operated in mono mode? I recently purchased a used dam1021 and it seems to be operating in mono mode. I would like to operate it in stereo mode but can't find how to do so. I have looked through this thread and a couple others.
Thank you.
Old 21st July 2019, 10:07 AM   #1118
TNT is offline TNT  Sweden
Have you been able to reach the command interface? There you do the setting. Of course it can do stereo.
More distortion to the people!
Old 21st July 2019, 07:09 PM   #1119
Thank you, I was beginning to suspect that was the place I needed to make the change. I have to setup a terminal emulator but I think I can do that.
Is the command "set mode=stereo"?
Old 21st July 2019, 08:17 PM   #1120
Sound about right - better check manual
Soekris' DAC implementationsHide this!Advertise here!
The DAC "do you have experience with this dac", Best diy dac for the money? murphythecat8 Construction Tips 9 17th March 2014 07:30 AM
WTB V2.6 PCB for ES9023 / WM8804 S/PDIF DAC –SUBBU DAC grufti Swap Meet 0 26th November 2012 05:51 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
Sabre DAC implementations SunRa Digital Line Level 1 18th December 2010 04:35 PM
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Copyright ©1999-2019 diyAudio
