Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#511 |
Attached a part of an interesting document about the sine wave to TTL conversion.
As you can see in table 3.1 the C-MOS logic approach shows the best performance in phase noise test, much better than high speed comparator and also better than ECL converter. |
#512 |
Those performance numbers should also put into perspective what is possible to achieve. Getting better than -100 dB at 1 Hz and -130 dB at 10 Hz probably won't happen with the available technologies. Not even if you use space shuttle tiles.
A quick back of the envelope calculation suggests about 70 fS random jitter with the kinds of numbers shown. (Good calculators here: https://www.jitterlabs.com/support/calculators/) I suspect that would be well below anything possible with a 24 bit DAC in otherwise perfect conditions. I still have not seen a real 24 bit DAC that runs at audio frequencies.
Demian Martin Product Design Services |
#513 | |
![]() Quote:
The document you provided is a little outdated. There is better logic now: tinyLogic, VHS and what not. Also comparators have been a lot improved since the LT1016. Just check with Analog Devices, Linear Technology, Maxim etc. ![]() |
#514 | |
If you are looking for faster logic device you can use Potato logic, as specified in the BOM. I don't see any reason to test other comparators, since the distance against the '04 is 30dBc or more. That's confirmed in the phase noise plot showed in post #5. Furthermore, I don't own a R&S FSUP to do the comparative test, so I think it would be better to follow a well tested way that ensures good performance, like the picogate. |
#515 |
This is a simple oven to be used with SC-cut crystals.
Board size is 1" x 1.4", compliant with TWTMC oscillators. The crystal fits into the PCB slot. It should be soldered to the top and the bottom of the PCB. I'm also looking for a copper clamp to solder to the PCB. In this case the crystal will fit into the copper clamp, without any soldering. Components values have to be adjusted for the right temperature. The TWTMC-C Colpitts-Clapp oscillator is not the ideal for SC-cut crystal, but the higher Q of the crystal could help anyway. Next step I'll start designing the Butler two transistors and the Driscoll oscillators, more suitable to work with SC-cut crystals. |
#516 |
Crystals have just arrived, all with individual test (attached).
Let me give all a try to check they start at the right frequency , and to define the final component values for each frequency. Then I'll begin the shipment to all the members. Follow the list of the members who required assembly service, I'll ship their items to Phil (korben69) who provides the service: esgigt thorstenlarsen mcluxun noizas Clsidxxl hirez69 zenelectro Ryssen JethroTull triodehunter tods Lindamar I ask Phil to confirm the acknowledgment of the service for the above members. |
#517 |
Banned
Hello Andrea,
Thank you so much for all your sharing and great efforts, Is there a BOM somewhere in relation to the boards you provide with the XOs ? regards |
#518 |
Thank Andrea,for your work
#519 |
#520 | |
Each crystal comes with a number written on the metal can, so you can refer to the testing sheet I have posted to know the specs of the crystals you will receive. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
low jitter crystal oscillator IC beta tester needed. | yizhou | Digital Line Level | 4 | 28th April 2013 06:13 AM |
Circuit wanted for a Low Phase noise 100MHz Clock | JohnW | Digital Source | 58 | 26th June 2012 09:28 AM |
New Ultra Low Phase Noise Oscillator from Crystek | wktk_smile | Parts | 7 | 25th August 2011 08:16 AM |
Low jitter 30MHz crystal oscillator? | Kuro | Parts | 2 | 1st April 2010 01:27 AM |
Tube Crystal Clock Oscillator | poynton | Everything Else | 3 | 25th August 2008 06:32 PM |
New To Site? | Need Help? |
