The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
Thread Tools
Old 20th June 2021, 09:11 PM   #3921
wlowes is offline wlowes  Canada
wlowes's Avatar
That was the basis for my implementation decisions as well. Supersurfer commented on the fist gen WTMC that it was not significant to move to batteries based on his subjective listening. There are lots of good linear supplies or easy to build if so inclined. No need for supercaps etc. Just a decent low noise reg after a well filtered supply IMHO.
Old 21st June 2021, 02:19 AM   #3922
diyiggy is offline diyiggy
diyiggy's Avatar
I tried on the Ian Masterclock , LT3042 reg, LiPoFe direct and with this reg and TS7A Ti reg from a good R-Core traffo : this last won from a large margin with little help of th FCA CAP. I'm not surprised you find a good power supply good enough.
Have to test the always power on clock, I have no doubt seing your testimonials it will be better. Let see where Doede/Supersurfer experiments go as well.
Pi VII au bord du P.
Old 21st June 2021, 04:12 PM   #3923
SimonJ is offline SimonJ  United Kingdom
First clock built and working
File Type: jpg 8B600D56-7078-424A-BA32-4F2AAAA822A2.jpg (978.5 KB, 361 views)
Old 22nd June 2021, 06:45 PM   #3924
diyiggy's Avatar
Ca rigol pas ! Nice little scope
Old 24th June 2021, 05:53 PM   #3925
bbest is offline bbest
Hello!
I get on hands:
1) 2pcs TWTMC-DRIXO (22.5792 and 24.576 MHz)
2) 2pcs TWTMC-STS (Sine to square converters)
How much power supplies must be used:
- 1 for two TWTMC-DRIXO (18V) and 1 for two TWTMC-STS (5V)
- or 2 for each TWTMC-DRIXO and 2 for each TWTMC-STS
Old 24th June 2021, 06:45 PM   #3926
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
1 for two is fine.
Old 24th June 2021, 08:38 PM   #3927
Supersurfer is offline Supersurfer  Netherlands
Wouldnt this create interference between clock families through the power supply?
Old 24th June 2021, 09:21 PM   #3928
dddac is offline dddac  Germany
DDDAC Audio
dddac's Avatar
In principle Yes, unless the Output impedance of the PSU is Zero. Hence shunts and ultracaps do a nice job.
Also the design of the clock circuit will have ways to decouple itself from the PSU
But even when yes, the question is how much do they influence and is it noticeable.
Andrea can shine a light on this as it is his design, how much the clock will allow interference when connected to one psu at a certain output impedance (as function of frequency) and may be get us a clue in which frequency range the power supply is most likely to interfere the clocks when impedance is not low enough
See my new Blog Site
Happy listening and building
Old 24th June 2021, 10:26 PM   #3929
Joseph K is offline Joseph K  Hungary
in theory, these clocks present a totally constant, fix current draw: 69mA for the 2x MHz case, here.
The output pure, single freq RF signal has no chance to appear backwards on the PS line.. if not by EMI/RFI radiation conductance and pickup..
So again in theory, easier case is hard to find.. they need low noise 16V cca, constant current draw 140mA for two, and go..
Old 24th June 2021, 10:43 PM   #3930
Yes, they are constant loads so there is no current modulation, the simplest load for a regulator.
Moreover the DRIXO circuit has very good rejection to the PS noise.
The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillatorHide this!Advertise here!
Thread Tools
low jitter crystal oscillator IC beta tester needed. yizhou Digital Line Level 4 28th April 2013 05:13 AM
Circuit wanted for a Low Phase noise 100MHz Clock JohnW Digital Source 58 26th June 2012 08:28 AM
New Ultra Low Phase Noise Oscillator from Crystek wktk_smile Parts 7 25th August 2011 07:16 AM
Low jitter 30MHz crystal oscillator? Kuro Parts 2 1st April 2010 12:27 AM
Tube Crystal Clock Oscillator poynton Everything Else 3 25th August 2008 05:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
