The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
Thread Tools
Old 14th January 2021, 10:40 AM   #3461
wgh52 is offline wgh52  Germany
Hello Andrea,
please be so kind to give me application advice.The FIFO + Masterclock combination looks similar to a reclocker to me which I employ in the form of a Mutec MC-3+. This unit has a 10 MHz Masterclock input (not a Wordclock input!). My questions:
- Is there a viable 10 MHz output option of the well tempered master clock? What would have to be done to produce a 10 MHz output quality comparable to the results in this thread?
- Would you even recommend to use this clock for the master clocking of other devices than DACs? ...e.g. for ADCs or reclocker with master Input?
Thanks and Regards,
Winfried
Perception is reality
Old 14th January 2021, 10:51 AM   #3462
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
At this moment a 10 MHz oscillator option is not available.
BTW is not a problem to get the DRIXO or the EXO oscillators to run 10 MHz, the real issue is the crystal since the manufacturer asks for a MOQ of 10 pcs.
The DRIXO and the EXO oscillators are state of the art devices, in the region of the best oscillators on the market, so you can use them as master clock for whatever application.
Old 14th January 2021, 02:55 PM   #3463
Thanks for the great clarification Andrea!
I do have an application using a TI PCM4222 ADC eval board. Sample rate is fixed at 24Bit/96kHz output. Which 24.576MHz oscillator type out of the list would be most appropriate or optimal here?
If more people were interested in building a 10MHz DRIXO or EXO Masterclock, maybe we can join and buy x-tals as a group...?
Thanks and Regards,
Winfried
Old 14th January 2021, 03:28 PM   #3464
There was a posting lately which listed the pdf links to the different XO types descriptions. Hell! I just can't seem to find that anymore... Maybe someone can point me to that posting?
Thanks!
Winfried
Old 14th January 2021, 03:42 PM   #3465
Thanks and Regards,
Winfried
The most appropriate oscillators for 24.576 MHz are the TWTMC-DRIXO or the TWTMC-EXO.
About the 10 MHz oscillators if the MOQ of 10 pcs will be achieved there is not problem to arrange the group buy, although I believe for the next GB because this GB is closed.
Old 14th January 2021, 03:44 PM   #3466
Thanks!
Winfried
In the first post you can find the links to all the documents about the new oscillators.
Old 14th January 2021, 05:29 PM   #3467
sebbyp is offline sebbyp  United Kingdom
Thanks and Regards,
Winfried
I would be interested in 10 mhz..
Old 14th January 2021, 06:25 PM   #3468
Supersurfer is offline Supersurfer  Netherlands
Originally Posted by lindamar View Post
would you care to share which DHT are you playing with ?. I am in search of a nice design for a 2A3 with an interstage transformer. Any hints would be gladly welcomed
I have build an amp that is very flexible in use. I have had countless tubes and schematics build in this chassis.
When I had a 2 way speaker filtered at 200Hz it was equipped with 2 SE output stages using PX-25 and later AD-1 tubes including active filtering, interstage coupled to the driver tube.
Now I power a wideband open baffle speaker with a balanced AD-1 output stage. All stages are coupled with Tamura interstages.
You can PM me if you like more information.
File Type: jpeg EC20F876-5125-4911-AF09-048D2BF9B4E6.jpeg (334.2 KB, 282 views)
File Type: jpeg 648DC981-9B24-4E5B-B634-502253BCC065.jpeg (236.5 KB, 284 views)
Old 14th January 2021, 06:37 PM   #3469
Hi Andrea,
Is there already an approx. date when the pcb semi finished boards will be delivered?
Old 14th January 2021, 07:48 PM   #3470
I should receive the semi-finished boards within the end of this month, the finished boards and the MC transformers within the first week of February.
But the longer lead time is for the crystals, the manufacturer has not yet told me the delivery date.
I believe I will start shipping in a month but only to those who have not ordered crystals.
The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillatorHide this!Advertise here!
Thread Tools
low jitter crystal oscillator IC beta tester needed. yizhou Digital Line Level 4 28th April 2013 06:13 AM
Circuit wanted for a Low Phase noise 100MHz Clock JohnW Digital Source 58 26th June 2012 09:28 AM
New Ultra Low Phase Noise Oscillator from Crystek wktk_smile Parts 7 25th August 2011 08:16 AM
Low jitter 30MHz crystal oscillator? Kuro Parts 2 1st April 2010 01:27 AM
Tube Crystal Clock Oscillator poynton Everything Else 3 25th August 2008 06:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
