The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
Thread Tools
Old 11th January 2021, 10:50 PM   #3451
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
Yes, 1kV DC is scary.
Old 11th January 2021, 10:52 PM   #3452
diyiggy is offline diyiggy
diyiggy's Avatar
well can be more with a 845
The Paradox of the anti-stupidity vaccine : the fools don't want to take it...
Old 13th January 2021, 02:54 PM   #3453
Preview of the whole Lite system under testing.
Old 13th January 2021, 03:40 PM   #3454
G600 is offline G600  France
A beast coming!
Old 13th January 2021, 05:07 PM   #3455
lindamar is offline lindamar  Spain
lindamar's Avatar
Exciting news Andrea !!
With regards to the I2S receiver, it seems to be HDMI right ?
I am definitely in for the DAC and the FIFO
Old 13th January 2021, 05:19 PM   #3456
Yes, the I2S receiver is over HDMI, it's the TWSAFB-RX.
The transmitter is the TWSAFB-TX.
Old 13th January 2021, 06:48 PM   #3457
BPatrik is offline BPatrik
Andrea. Do you think that HDMI interface for I2S is optimal?
Old 13th January 2021, 09:01 PM   #3458
laserscrape is offline laserscrape
HDMI is before the fifo+isolator, it shouldn't make any difference.
Old 13th January 2021, 10:24 PM   #3459
I think the source is not much important, the FIFO should isolate the DAC from the source since they work in different time domains.
Old 13th January 2021, 10:31 PM   #3460
Yes, the jitter coming from the source cannot affect the DAC because the FIFO isolates them.
Data incoming from the source are stored in a memory and then they coming out with a different master clock, the FIFO is asynchronous.
The quality of the output depends on the quality of the FIFO master clock.
The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillatorHide this!Advertise here!
Thread Tools
low jitter crystal oscillator IC beta tester needed. yizhou Digital Line Level 4 28th April 2013 06:13 AM
Circuit wanted for a Low Phase noise 100MHz Clock JohnW Digital Source 58 26th June 2012 09:28 AM
New Ultra Low Phase Noise Oscillator from Crystek wktk_smile Parts 7 25th August 2011 08:16 AM
Low jitter 30MHz crystal oscillator? Kuro Parts 2 1st April 2010 01:27 AM
Tube Crystal Clock Oscillator poynton Everything Else 3 25th August 2008 06:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
