Which is the real TDA 1543 ??
Old 20th July 2014, 11:46 AM   #21
kp93300 is offline kp93300  Malaysia
I am using the IV from rbroer
this is the circuit.
I used bc550 and 560 C grade instead of BC 547, 557 B . .
D1 and D2 do not light up.
Old 18th August 2014, 12:24 PM   #22
freax is offline freax
freax's Avatar
I would like someone to comment on my recent procurements of 4x TDA1543
They appear to be genuine but I would like someone with a bit more experience to come along and contribute what they think.
Test #1
I have examined all four of them underneath a microscope and the plastic glue which mates both the top and bottom parts of the integrated circuit package together is identical to a pair of 100% Genuine 555 timers that I've got as a hand-me-down from the 1970s-1980s which were originally purchased through Farnell. That is a point towards them being genuine.
Test #2
I have seen under the microscope that there is a significant amount of sand and hair surrounding the pins of the new TDA1543 IC's, which the original 555 Timer's also have. Which is another point towards them being genuine. NOT enough to make me suspect that they have been sandblasted, just buildup from being in those plastic ribbon storage containers.
Test #3
However what subtracts a point from them being genuine is that the pins have some signs of scratching on the sides of the pins. NOT heavy scratching that you would find from sandpaper, just stuff that looks like meteorites. There is NO visible signs of solder or tinning aside from the manufacturer's usual tinning. So they are NOT a working pull from a device that was done by the chinese. So its 50/50 wether its genuine or not.
Test #4
There is no signs, as far as I'm aware, of the surface of the chips being sanded back and them being repainted. However the text print ontop makes me nervous. This is a test which I am unsure if it makes them more genuine or fake.
Test #5
The text ontop of each IC is of a different size and consistency to the known-genuines, however it is the same material of the genuine ones and it is not wildly out of spec. It produces the same view that you get from the genuines of looking down from space onto snow covered mountaintops while looking underneath a small pocket microscope. It appears to be applied the same way as the genuines. Which makes identifying these chips as genuine or fake so difficult...
The TDA1543A and the TDA1311A are BOTH 100% Genuine.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 18th August 2014, 01:01 PM   #23
freax's Avatar
Test #6
The text string of the Questionable TDA1543's are closer together than both the TDA1543A and the TDA1311A. 1 more point in the fake category.
Test #7
The white stripes to the left of the Questionable TDA1543's come into contact with the Indent of each IC. This is not the case on the TDA1543A. 1 more point in the fake category.
Test #8
The surface of the chip should look like what is shown in the first attached photo. Under a microscope it looks exactly the same as the genuine TDA1311A and I also see bits of glass embedded into the plastic package. This is 1 point in the genuine category. It is not smooth at all and is a rough surface, this can most easily be seen around the text. Most importantly the surface appears to be pitted randomly and it doesn't contain parallel lines indiciative of sanding.
Old 18th August 2014, 01:40 PM   #24
freax's Avatar
These appear to be genuine.
What tipped it for me in favour of being genuine was finding sand and surface corrosion on the four small gaps around the copper leads which come out the very end of both sides of the TDA1543 IC's. That and the lack of evidence of any blacktopping.
The variations which I have seen are as far as I'm concerned within normal manufacturer variations.
The 4x TDA1543's appear to be a match somewhere inbetween the TDA1541A and the TDA1311A appears to be the closest match. Which makes logical sense. The TDA1541A is a much older chip than the TDA1311A.
Considering that these TDA1543's all come from the same source and the same batch, it is logical to assume that they will also all look the same but with some minor variations.
I will now have to wait to do functional testing.
Old 19th August 2014, 12:49 AM   #25
Default working tda 1543
This is the second batch of TDA 1543 purchased from aliexpress.
It is working as expected
Old 19th August 2014, 01:28 AM   #26
freax's Avatar
Do you notice the white sheen on the entire chip surface? its possible that this was another IC and has been remarked. I don't see much sense in remarking a TDA1543 so its probably something else which is functionally the same as one.
It is something that I am trying to avoid buying.
Also, notice how the TDA1543 string of text begins closer to the left hand side of the Philips logo instead of to the far right of the Philips logo like it does on all of mine except for the TDA1311A. Not all Chinese knockoffs begin like this but a LOT of them do as far as I've seen so far.
Would you please re photograph that in a different light? A warmer light? I would like to see it in a different light so I can compare it to mine.
Thank You.
Old 19th August 2014, 02:09 AM   #27
i will take more pictures when i am at home later
Old 19th August 2014, 01:54 PM   #28
More photo as requested
Old 20th August 2014, 07:24 AM   #29
Jempie is offline Jempie  Indonesia
I have found the real one
3.55 euro
Old 21st August 2014, 12:54 AM   #30
Jempie,
Can you post some images of the TDA1543 and where is the source?
kp93300
Which is the real TDA 1543 ??Hide this!Advertise here!
TDA 1543 Distortion problems adamgillingham Digital Line Level 34 3rd March 2015 03:50 PM
TDA 1543 - How hot? pixpop Digital Source 11 12th January 2006 09:37 PM
Tda 1543 buying robbie Digital Source 5 10th August 2005 02:41 PM
Tda 1543 Chris Digital Source 5 23rd October 2003 10:39 PM
tube rectifier and tda 1543 Raj1 Tubes / Valves 9 31st August 2003 06:00 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
