Signalyst DSC1
Signalyst DSC1
Thread Tools
Old 5th May 2021, 09:00 PM   #1961
nautibuoy is online now nautibuoy  United Kingdom
nautibuoy's Avatar
I've been dusting off the old grey cells and checking out the botic configuration settings...
Old 5th May 2021, 09:13 PM   #1962
nautibuoy's Avatar
Originally Posted by nautibuoy View Post
I should add that the Acko SO3 is equipped with 90MHz family NDK oscillators.
That should be KHz of course
Old 5th May 2021, 10:03 PM   #1963
nautibuoy's Avatar
Fixed it and now playing music with the Pure software running as an MPD UPnP renderer. I had forgotten that my SO3 isolator with 90KHz oscillators had the clock divider set at 1:4. Set the clock frequencies correctly in optargs and all is well.
Old 5th May 2021, 10:35 PM   #1964
gionag is offline gionag  Italy
Signalyst DSC1
90 Khz ?
Old 5th May 2021, 10:44 PM   #1965
nautibuoy's Avatar
I'm old and easily confused nowadays - I was right first time, the NDK oscillators in my Acko SO3 isolator/reclocker are 90 and 98MHz.
Old 5th May 2021, 11:32 PM   #1966
Signalyst DSC1
... no worries, i was just curious about something that I may have missed
Old 6th May 2021, 11:47 AM   #1967
JPS64 is offline JPS64  Germany
Could someone supply the drawing with dimensions for this 10k:10k chinese transformer?
JP
Old 6th May 2021, 12:55 PM   #1968
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I don't have any drawings but a quick check with my verniers reveals the 10k+10k trafos I have have 4 pins on one side spaced at 0.2" intervals. The spacing of the two rows is on a metric (not 0.1") grid for some reason, 12mm between them.
For the silkscreen, width is 25.5mm and depth is 17.5mm.
I know everything you know about this times 1000 - Amir @ ASR
Old 6th May 2021, 01:14 PM   #1969
Thank you @abraxalito.
Supposing soldering pins 1mm?
Do you´ve the reference of the one you used?
JP
Old 6th May 2021, 01:19 PM   #1970
abraxalito's Avatar
I've used a few electrical configurations but mechanically they're the same EE25 core set. This one is my most recent purchase - there are measurements on the page I see now.
The pin diameter is 0.7mm.
600:20K?????????????? ???? ???????-???
Signalyst DSC1Hide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
