Signalyst DSC1
Signalyst DSC1
Old 31st July 2020, 07:07 PM   #1901
ppy is offline ppy  Russian Federation
ppy's Avatar
Simple DSD SRC for BeagleBone
Old 1st August 2020, 03:04 AM   #1902
CrowDaddy is offline CrowDaddy
Default high quality tube output board
The high-quality tube output (I/V) board used on the RAKK DAC is currently available from K&K (Kevin Carter):
Raleigh Audio Line Stage – K & K Audio
Scroll about halfway down the page and you will see the linestage boards; these are the same as used for the output board in the RAKK DAC, with the mounting locations for the tantalum current-to-voltage resistors visible on the edge of the board. K&K have an excellent reputation, so these should be a great choice of output converter for anyone wanting a modern tube circuit, with constant current source plate loads and shunt regulators.
Old 2nd August 2020, 09:11 AM   #1903
Brzzl is offline Brzzl  Europe
Signalyst DSC1
Default BOM of last DSC2 prototype
@ppy
Hi Pavel, I am thinking about building your last prototype but ran into a problem with your BOM
I don't know whether I should order the component that matches with the name in your BOM, or the one that matches with the datasheet in the BOM.
Please let me know, or even better, fix the BOM as a last and final thing before you leave the project completely behind you, so that everyone knows what you inteded your final version of the DSC2 to look like.
Old 2nd August 2020, 12:31 PM   #1904
Signalyst DSC1
Originally Posted by nguyentanvu90 View Post
I think here it is an layout error.
Oh and Pavel, would you please comment on/fix the layout error. Thanks
Old 2nd August 2020, 01:21 PM   #1905
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
I'm enjoying an alternative approach to DSD playback - it's awesome.
Valve DAC from Linear Audio volume 13
Old 3rd August 2020, 06:51 PM   #1906
ppy's Avatar
I am no longer developing DSC2. The latest version is published "as is". This is a complete KiCad project with the sources. You can correct the errors yourself.
P.S. The latest firmware has changed the MUTE signal. The old Botic7 driver signal is still at 27pin. On 28pin I have implemented my own MUTE signal. It is more efficient with HQP and Roon.
Old 3rd August 2020, 08:30 PM   #1907
Signalyst DSC1
Thanks, I thought so, but it was worth asking plus I am not the best with KiCad...have you @nguyentanvu90 or anybody else corrected the KiCad project?
Good to know -thanks for the info Pavel.
Old 12th August 2020, 10:10 AM   #1908
nguyentanvu90 is offline nguyentanvu90
Hi Mark!
I can share for you 1 pcb and i will fixed on PCB before send to you.
Old 12th August 2020, 05:23 PM   #1909
Signalyst DSC1
Hi Mark!
Sent you a pm!
Old 30th August 2020, 07:41 PM   #1910
vitopro is offline vitopro  Italy
Hi Pavel,
i have built the DSC 2 dac 1 year ago. My question is: Is the last prototype significally better then mine?
It woth to build last version?
I'm happy if anyone can summarize the differences between old version and new one.
Signalyst DSC1Hide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
