Signalyst DSC1
Signalyst DSC1
Old 13th November 2019, 10:40 AM   #1651
Zoran is online now Zoran  Serbia
Originally Posted by randytsuch View Post
Audiodesignguide has a link for the transformers. Scroll down a little on his page.
PureDSD
Thanks Randy
Old 14th November 2019, 07:10 AM   #1653
ozcal is offline ozcal  Australia
Hi guys , quick question : If I am using the dac in rca output mode do I short the unused phase of the balanced output to ground
The reason I ask it that output seems very low compared to my dacs with opamp output stages.
Old 14th November 2019, 07:25 AM   #1654
Raj1 is offline Raj1  United Kingdom
Yes, you short the side of the transformer secondary to connected to the rca shield (return path) to ground.
Old 14th November 2019, 07:34 AM   #1655
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
ppy's build documentation has a section on connecting the output transformers, which includes schematics.
Old 14th November 2019, 07:37 AM   #1656
So + connected to rca hot and -ve and ground connected to ground?
Old 14th November 2019, 08:21 AM   #1657
Thanks NB , had a look but I am using the original (Chinese) DSC1 board and being a novice I can't figure out what to do. I am using the recommended 10K:10K Chinese transformers.
Old 14th November 2019, 12:41 PM   #1658
Yes.
Old 15th November 2019, 10:17 PM   #1659
koldby is offline koldby  Denmark
koldby's Avatar
Hi all
First my DSC2 is now the best I have heard after I changed my PS to LifePo4 batteri supply for the board and also for the amanero USB interface. Beware the DSC2 is a power hungry beast
Next.
Can we use this instead of the amanero?:
DIYINHK XMOS Multichannel 32ch USB to/from I2S/DSD SPDIF Interface | Dimdim's Blog
I really want a multichannel solution (at least 4 channel) so I can use audiolense to do the x-over filter for my line arrays to the subs I am planning...
What is Home Theatre without good sound?
Old 15th November 2019, 11:02 PM   #1660
Signalyst is offline Signalyst  Finland
Originally Posted by koldby View Post
This was much better sound wise and noise wise than with any other F-F I tried and I wonder if Pavels experiment with a DSC1 made with F-F (Signalyst DSC1 post #577) could be a winner, if 74AUC1G74 was used instead. IMHO the reason AUC1G is performing so well is that rise and fall times are almost equal and q and q bar is also very equal.
The NXP AHCT595's I'm using in the original DSC1 design have very nice characteristics (running from 5V PSU).
Any of 3.3V parts I've seen have horribly bad timing performance.
Maybe due to gate capacitances being less issue at higher voltages/current drives?
Signalyst DSC1Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
