Signalyst DSC1
Signalyst DSC1
Old 21st September 2019, 05:36 AM   #1551
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Originally Posted by nautibuoy View Post
do you have a mechanical drawing of your isolator/reclocker board available? I particularly need to know the position of pin 1 of the output header in relation to pin 1 of the BBB P9 header.
I think I've managed to obtain the relative positions of the pins by opening ppy's gerbers in the free (for non-commercial use) GerberLogix tool (the installed version not the on-line gerber viewer) and using its 'centre to centre' measurement tool. From that I can work out the BBB mounting hole positions. I'll finish off and check the measurements later but if it works out I'll have a suitable mechanical drawing.
Old 21st September 2019, 09:55 AM   #1552
Zoran is offline Zoran  Serbia
Originally Posted by gionag View Post
Made a simple but effective PSU for the DSC2.
CRC for the reclock (13200uf + 0.5ohm + 13200uf)
CRC for the analog output (13200uf + 0.5ohm + 13200uf)
5v Regulated for BBG (18800u + LM1084-5.0)
works like a charm.
Sound wise, to me, appear to sound as good as other more exotic solution.
so maybe. if someone needs a valid and quick psu this arrangement is worth a shot.
If someone trust me enough on that i can share pcbs or gerber.
Yes.
But is there any reason not to use CLC against resistor component?
Old 21st September 2019, 11:47 AM   #1553
gionag is offline gionag  Italy
Originally Posted by Zoran View Post
Yes.
i have thought that is already enough this way.
cheaper, quicker.
from simulation the clc is slightly better... but in the end, this board already has loacal regulators on-board with very high PSRR.
My concern was just to give the lower impedance source possibile rather to reducing ripple. (While containing costs).
Old 21st September 2019, 11:58 AM   #1554
lindamar is offline lindamar  Spain
lindamar's Avatar
works like a charm.
In Gionag we trust
In you don’t mind to share...I’d be interested (pcb and/or gerber)
Pepe
Old 21st September 2019, 12:06 PM   #1555
Originally Posted by lindamar View Post
In Gionag we trust
Please, don't
Old 21st September 2019, 04:25 PM   #1556
randytsuch is offline randytsuch
The interface connectors used on Pi's and BB boards will be a tenth of an inch apart or 0.1 inch.
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 21st September 2019, 05:38 PM   #1557
nautibuoy's Avatar
Yes, that's a given - it's the relative position of pin1 of the reclocker output header I needed. I plan to stack the reclocker/BBB compo under a DAC board so needed to deduce the position of the holes for the different board stand-offs. All done and checked now though.
Old 22nd September 2019, 07:36 AM   #1558
cheaper, quicker.
Maybe to try some shunt end with say additional 120% of consumption?
I have similar experiences with no-feedback, simple, old-school power supplies. Somehow sounds better?
Old 28th September 2019, 07:35 AM   #1559
potstip is offline potstip  Turkey
Hello;
In 2.5.2 bom nexpedia Shift register adviced but in new boardwith isolators philips or nxp adviced any reason?
Old 28th September 2019, 11:35 AM   #1560
MarcelvdG is offline MarcelvdG  Netherlands
The semiconductor department of Philips became a separate company called NXP many years ago. More recently a part of NXP split off and became Nexperia. I don't think all these reorganizations affect the performance of their shift registers.
Signalyst DSC1Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
