Thanks, first I need to finish DSDit .. i cancel the order for the avr becouse I found a arduino nano in store next door .... tomorrow the attiny arive ....
In second place i will "repair" DSD512 .... As u say I think the Amanero is the problem not the dac becouse DSD256 works thats right? ..
If I remember correctly, the Amanero did only reliable DSD512 with the CPLD_1081 and 2000be11 firmware. Are you using that?
For the DSC3 the Amanero must be used with the slave_for_1081. To set the configuration bits right, you have to change the number _071a to _0a23. See attachment. With this driver software, DSD512 should work also with the Amanero.
