Signalyst DSC1
Signalyst DSC1
Old 31st March 2019, 09:30 PM   #1291
christian.lenci is offline christian.lenci  Italy
The DSC2 can be supplied using a single 6 to 10V DC line.
About NXP 74AHCT595, last month Mouser shipped to me NXP chips with "1545" datecode, I think they should be pre-Nexperia. In any case, I am using them and I can assure they leave nothing to be desired If someone plans on buying them, exact P/N is 74AHCT595D,112.
Just a clarification about my previous post about reflections and terminations on clock lines: I did not set the Amanero board on slave mode, with reference to MCLK. Once corrected that, CLK waveform did not differ with or without termination resistors, so I removed them. The board is working perfectly now.
I have some doubts myself now:
-What are correct firmware versions for Amanero when using DSD512 on Windows? I am using DSD512x48x44 for the CPU and Slave_for_1080 for the CPLD. Is this correct?
-I did not mount the 2200pF capacitors across transformer primary, is this correct?
-I am using LL1684 output transformers and input impedance of my amplifier is exactly 10K. Is it advisable to lower the impedance to 5-7K or is this only needed with chinese transformers?
Old 7th April 2019, 03:52 PM   #1292
ppy is offline ppy  Russian Federation
ppy's Avatar
I think that the most stable firmware for Windows is firmware_1096c. With this firmware no artifacts on DSD512.
The choice of this capacitor by measuring the frequency response with Chinese transformers. But many users said that reducing to 330-470pf or deleting it is good for the sound.
You do not need to reduce impedance.
Old 7th April 2019, 04:03 PM   #1293
ppy's Avatar
Originally Posted by vitopro View Post
where i can find a mounting plan?
Another qustion: i bought a pcb from a user on this forum. But he not supplied me resistor network pcb. Is there a way to Mount resistor network without dedicated pcb (on the dac pcb)?
Mounting plan is not available. Give me a few days and I will post it on puredsd.ru.
The PCB resistors I have are in great abundance. I can send you.
Old 7th April 2019, 04:54 PM   #1294
vitopro is offline vitopro  Italy
Many thanks Pavel, i have already ordered pcb. I wait for mounting plan.
Old 8th April 2019, 10:31 AM   #1295
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
Attention guys I don't hear any kind of pop click using abraxalito 4th passive filter when I change formats between DSD & PCM or viceversa, only a pop when power on I guess because I don't use a bleeder resistor after the output capacitor. Attached schematic.
Old 10th April 2019, 09:57 AM   #1296
ppy's Avatar
Mounting plan added to http://puredsd.ru/mounting_plan.pdf
Old 10th April 2019, 06:15 PM   #1297
gionag is offline gionag  Italy
If someone is interested, i have found a supplier that has in stock the phlips 74AHCT595.
They are recommended over new nexperia / ti.
The problem is i have a quote for 100pcs and i need 20.
If someone want to share a quote on the lot, i can arrange all the shipments and payments.
Let me know
Old 10th April 2019, 07:56 PM   #1298
Many thanks Pavel!!!
Old 12th April 2019, 06:09 PM   #1299
lindamar is offline lindamar  Spain
lindamar's Avatar
Let me know
Count me in gionag ! Pm with details if you want to proceed right away
Cheers
Pepe
Old 12th April 2019, 06:24 PM   #1300
Cheers
Pepe
i have others on pm that still miss confirmation.
if other 3 confirm their interest i will place the order and give you back.
we need to reach 100pcs for the moment, and i think we are on it if all of the people interested confirms me their intention.
Signalyst DSC1Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
