Signalyst DSC1
Signalyst DSC1
Old 14th March 2019, 09:56 AM   #1281
ppy is offline ppy  Russian Federation
ppy's Avatar
Yes you are right. In your case, this is the effect of the reflected signals on the line.
But I had no such problems. It was made 3 copies, and they had no noise.
Could you show a photo of your board?
Old 14th March 2019, 06:06 PM   #1282
RushBattle is offline RushBattle  United States
Signalyst DSC1
Howdy All,
Looking for some input on power supplies for a DSC2 V2.5.2 build. Looks like I need 5V for Amanero, and the same for each channel on DSC2. I also need a +/- 18V bipolar supply for my output stage. It would be nice to have each supply on its own PCB including the transformer. Anyone have any recommendations? I’m in the US, so 120V mains. Thanks for any ideas or pointers!
Old 15th March 2019, 04:58 PM   #1283
lindamar is offline lindamar  Spain
lindamar's Avatar
My apologies if rhe following question has been alredy made.
My setup is a dsc 2.6.2 with amanero firmware 1099c. I play music in my home network with HQPlayer and a raspberryPi3 with DietPi. Amanero is connected to the Pi via USB.
That setup plays beautifully but I have a huge blop (or click) whenever the family rate changes (say playing 44.1khz music file and thereafter 96Khz file). It also has that problem with native DSD files which have different family rate.
Does anybody have a similar problem ? How did you solve it ?
Cheers
Old 15th March 2019, 05:19 PM   #1284
ppy's Avatar
Firmware 2002 and higher work best with the mute signal in Linux.
Old 18th March 2019, 09:03 AM   #1285
Ipoci is offline Ipoci  Italy
Tested my DSC2.5.2 with resistance installed on R65 R129 ... then rolled back to default configuration. An oscilloscope is probably needed for a real fine tune ... I will try to buy a decent one.
Question. I use BeagleBoneBlack as a NAA. What should be the right set for the parameter <DAC bits> on HQPlayer? 32, 24, Default?
Old 18th March 2019, 10:25 AM   #1286
lindamar's Avatar
Thank you ppy, I will try to update the firmware then
Old 21st March 2019, 09:43 PM   #1287
vitopro is offline vitopro  Italy
Hi Pavel,
where i can find a mounting plan? I am not able to solder smd so i wan use a outsourcing company. But they asked me a mounting plan.
Is there somebody can help me?
Another qustion: i bought a pcb from a user on this forum. But he not supplied me resistor network pcb. Is there a way to Mount resistor network without dedicated pcb (on the dac pcb)?
Old 24th March 2019, 02:06 PM   #1288
Brzzl is offline Brzzl
Does someone know a place where I can get genuine old Philips or NXP 74AHCT595?
+What is the most acceptable substitute for old 74AHCT595? Nexperia, Diodes Incorporated, Texas Instruments, or a different brand?
I would especially be interested in a reply from Pavel, but anyone's help is greatly appreciated! -Thanks in advance!
Old 24th March 2019, 05:35 PM   #1289
2A3SET is offline 2A3SET  Canada
PMed
Old 26th March 2019, 05:55 PM   #1290
I'm considering giving the DSC2 prototype a try. What Voltages DC do I need to supply?
5VDC for the Amanero, but what about the DSC2 itself?
Signalyst DSC1Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
