Signalyst DSC1
Thanks, first I need to finish DSDit .. i cancel the order for the avr becouse I found a arduino nano in store next door :).... tomorrow the attiny arive :)....
In second place i will "repair" DSD512 .... As u say I think the Amanero is the problem not the dac becouse DSD256 works thats right? ..
If I remember correctly, the Amanero did only reliable DSD512 with the CPLD_1081 and 2000be11 firmware. Are you using that?
For the DSC3 the Amanero must be used with the slave_for_1081. To set the configuration bits right, you have to change the number _071a to _0a23. See attachment. With this driver software, DSD512 should work also with the Amanero.
I have problem with flash the amanero.... I erase amanero
I set all like on the screen ... but now amanero dosent support asio and its dead dsc3 dead..
My amanero in oemtool is recognized as _071a .... how to change it? to proper one?
When i erase flash and set CPLD 1080 and 1966c with settings for the dsc2 not in slave mode amanero is recognized ok by the windows and hqp plays OK
But when I do it like last time when dsc3 works OK with dsd256 now it dosent work anymore (slave).... PC problems or what?
I just change FW and settings and a cant bring back dsc3 to live
I dont remember what driver i have months ago 71 or 23...
There is some screens :
Combo384 shows when amanero is programmed in DSC3 type - not recognized by HQP
Amanero tehnologies when its programmed in DSC2 type - recogized by HQP
What sometimes happens is that flashing the CPU doesn't happen while you think it should.
Solution is: first erase. Plug USB out and in. Then flash CPLD with slave_for_1080. Then USB out and in . Then flash CPU with 1096c.
Then set configuration bits. With 1080 the last number is _071a.
With 1081 you should change the number _071a to _0a23 otherwise Write Flash gives back that device is not found.
Trying slave_for_1081 and 2006be11 can be useful to get DSD512 to work but with 1080 and 1096c DSD256 should work flawlessly.
If you got the DAC running once, chance is 99,99% that it is still working and that you have a problem with correctly flashing the Amanero.
