If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, or
Old 26th March 2014, 05:35 PM   #1
ag8908 is offline ag8908  United States
Default If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, or
If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, or a 9v 600mA power supply? I ask because I have both. I have been using the 2000 mA one, but I want to make sure that's not a problem.
TYIA
http://www.ebay.com/itm/PD05-XMOS-PC...item1c3e264a44 and it says "External power can be DC 7V-9V, can provide better purity and abundant current , sound more natural.
What is the optional external DC power supply " and then it links to a power supply that is 9v 1660 amp. If it's linking to and recommending a 1660 amp supply, then I assume the 9v 2000 amp supply is OK?
Old 26th March 2014, 06:14 PM   #2
Eldam is offline Eldam  France
Banned
Do you talk about a regulated voltage and the current it can allow at its output or do you talk about the transformer as well ?
Do you know the max current cunsumption of the DAC ? Go with equal or more if you have a all in one PS (transformer + regulated voltage pcb)
I read somewhere (ECDesign thread) than a good transformer has to match the load needed for current in digital design for better results.
If the secondary curent is below the need of the load you will have saturation, noise... something like that (same with all type of design like the analog one). In the worst scenario if you have no fuse at the secondary it can break all. I think we talk about nominal current here because peak to peak its around 4 to 5 x bigger. The VA value of a transformer is what it can absorb max at the primary.
If the secondary is abble to give much more current than the load need, there is no danger, the load pull what it needs. But it seems to be better in digital domain to match the transformer with the need of the digital load.
The transformer is better if not torroid (toO big bandwith allow more harmonics noise of 50/60 than a classic transformer) and shielded.
If you talk about voltage regulation only : you need at the output (after bridges diodes, regulators) to try which value work the best if the DAC can really work with values between 5 to 9 V but of course never overtake the maximun voltage needed by the DAC: 9V). because if it's a DAC kit (I don't talk about the DAC chip itself), there is also analogic outputstages and most of the time it works better with the max voltage it can support !
Wait & check with others answers before, here it's just a two cents answer as beginning, maybe the ref or a link to yours PS will help... the link you gave here doesn't work.
Old 26th March 2014, 06:24 PM   #3
thanks, so it seems like the 2000mA one is the better choice between these two
If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, orHide this!Advertise here!
9v AC power supply for DAC lordearl Digital Source 1 1st August 2013 02:28 PM
Help cleaning up ripple on 9v 6 chnl guitar pedal power supply Simbl Power Supplies 43 19th April 2013 06:28 PM
Special 9V supply Tarzan Power Supplies 14 17th February 2011 10:14 AM
Circuit Sanity Check: +15V, -15V, +9V Power Supply miallen Power Supplies 4 18th July 2009 07:18 PM
Need help with power supply, ~12v source: 9v, 5v, and 3.3v ouputs mbcouple Power Supplies 3 2nd September 2005 06:19 PM
Copyright ©1999-2019 diyAudio
