New Async XMOS 384K/32bit with PCM5102 DAC on ebay
Old 31st October 2013, 04:22 PM   #51
PreSapian is offline PreSapian
looks like de-emph is already selected. so then i cut the trace from pin 11 and connected that to where the ceramic cap is connected to pin 10 and viola... gorgeous sound. you must do this mod, haha.
Old 31st October 2013, 05:59 PM   #52
csickman is offline csickman
Could you show us a picture of the mod
Old 1st November 2013, 06:31 AM   #53
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
i was mistaken. the output of the dac goes to the input of tda1308. still, the rca + is connected to the same trace....
above picture is for iir mod. cut the trace leading out of pin 11 first.
Old 13th January 2014, 08:19 PM   #54
press57 is offline press57
I found a drivers that works with this board.They are for a Rega Saturn-R CD player.
http://www.rega.co.uk/downloads/XMOS...022(v2.15).exe
Old 23rd January 2014, 07:46 AM   #55
Tolu is offline Tolu  Germany
Tolu's Avatar
Does V1.4 from 2013/9/9 now work with 7-9V PSU or still with 5V?
Old 12th February 2014, 09:02 PM   #56
Ktronik is offline Ktronik
Originally Posted by andynz View Post
Ciao Ghiglie
Thanks for following the project! It's changing as it goes but I have pretty much decided on the following:
PCM5012A DAC Board (obviously!)
Raspyfi
RaspyFi - Pi never sounded so good!
Regulator Board
4.17uV Ultralow noise DAC power supply regulator (3.3V/5V 1A)x2 (+-12V/15V 1A)x1 - DIYINHK
Toroidal 230v - 2 x 6v AC transformer
Toroidal 230V Mains Transformer 15VA 0 6V 0 6V | eBay
And an ebay aluminum box yet to be ordered based on what size all the boards come to when I connect it up.
I think that should do it and with the option of installing a 2.5" external drive in the box I can have my entire collection, DAC & power supply in one little box.
This box looks like a good option with IEC and power switch. You would need to modify the rear panel holes possible.
2806 2 Aluminum DAC Enclosure DAC Box Case Suitable DAC7 DAC9 ES9018DAC 1541 | eBay
First time poster here...Hi everyone! , great project!! hows it going?? good stable build??
cheers Kerry
Old 19th February 2014, 04:58 PM   #57
grazie is offline grazie  United Kingdom
How do you mount this kind of PCB in an enclosure, as it has no holes for stand offs?
Old 21st February 2014, 01:34 PM   #58
lwtong is offline lwtong  China
Default es9023
Hello, everybody, the ES9023-I2sdac used on raspberry good use.
Old 26th March 2014, 05:35 AM   #59
supernut is offline supernut  Thailand
Dear PreSapian,
Just cut the old trace of Pin11 and wire Pin 11 to the left side of C49, am I correct? No need to pull out any Capacitor or Resistor right? and What is the purpose of this mod?
Old 9th May 2014, 04:03 PM   #60
Tolu's Avatar
Default Leaf Audio XMOS 384 k DAC
I got mine today and tried it out. It was a big disappointment because it has pops and crackles at 96 kHz sometimes at 44k. I changed the USB cables but always the same. My other XMOS DAC (iBasso D7) had never any pops or crackles regardless which kind of files up to 192 kHz.
So, any ideas how to fix it? Dust bin and better buying something with more quality?
New Async XMOS 384K/32bit with PCM5102 DAC on ebayHide this!Advertise here!
XMOS DSD 384 kHz / 32bit USB joro_s Digital Line Level 949 17th March 2019 01:11 PM
GB thread for XMOS DSD 384 kHz / 32bit USB joro_s Group Buys 223 15th October 2014 01:03 AM
FS: XMOS Async USB Interface/DAC adelias Swap Meet 1 13th March 2013 02:34 PM
Te7022 Ebay board+PCM5102+Alps RK27 Neutrality Digital Line Level 1 9th September 2012 12:40 PM
XMOS Async USB interface (UAC 2.0) dwk123 Swap Meet 1 16th August 2011 04:01 AM
Copyright ©1999-2019 diyAudio
