low pass filter for DSD
Old 1st May 2013, 06:58 PM   #11
Julf is offline Julf  Europe
Originally Posted by merlin el mago View Post
I have no idea that's the reason I'm asking help.
OK, but it sounds like you need help with much more than just a few component values. Doesn't your DSD DAC already have an output filter?
Old 1st May 2013, 08:20 PM   #12
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
I don't want to use my DSD DAC, only the filter + hi-gain tube stage.
Old 2nd May 2013, 12:57 AM   #13
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I suggest a 4th order LC filter for DSD. After all you'll want to aim for something approaching 120dB rejection at the switching frequency, which for DSD64 is 1.4MHz.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 2nd May 2013, 05:58 AM   #14
Agree, you need something much more complicated than just a first-degree filter - but a lot also depends on the HF behaviour of your tube stage.
Old 2nd May 2013, 06:01 AM   #15
Ah, I see. What kind of circuit drives your filter? What is the HF behaviour of your tube stage?
Old 2nd May 2013, 07:53 AM   #16
I don't know the HF behaviour of the tube stage, the tube stage to be used in attached pic.
Old 2nd May 2013, 08:00 AM   #17
Sorry my ignorance:
What Low pass filter: Butterworth or Chebyshev?
What is the corner frecuency necessary?
What kind of filter: series or shunt?
Old 2nd May 2013, 08:35 AM   #18
abraxalito's Avatar
Butterworth or Chebyshev would be fine - I suggest Butterworth as its simpler to design. The corner frequency depends on you - perhaps 50kHz -3dB would be fine as a first attempt.
A 4th order LC would have two series inductors and two shunt capacitors, followed by a resistive termination
<edit> Attached a schematic based on a design I did for an ESS DAC. Its Butterworth but 30kHz -3dB.
Old 2nd May 2013, 08:36 AM   #19
What is more important for you - steepness of the filter, or minimizing ripples?
As low as possible - I would put it at 22-25 kHz.
When you go beyond a simple first-order RC filter, it doesn't really make sense to talk about a series or shunt filter - if you implement the filter as a passive filter, it will have both shunt elements and series elements, and be a fairly complex filter with both inductors and capacitors - and making a 4th order passive filter is not easy! Usually some active buffer elements are used.
If you want to go ahead anyway, all the required formulas are here and here.
Old 2nd May 2013, 08:39 AM   #20
I am all for experimenting, but I have to ask what it is that you are hoping to accomplish? You are not likely to produce anything that has superior sound quality compared to systems designed by professional designers, and there is a real risk of burning out your tweeter or causing some other damage to your speakers.
low pass filter for DSDHide this!Advertise here!
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Low pass filter help ifrythings Subwoofers 1 24th February 2006 09:45 AM
Low Pass filter ThSpeakerDude88 Everything Else 4 8th November 2005 02:53 AM
low pass filter crazyant Car Audio 3 15th September 2005 06:15 PM
Copyright ©1999-2019 diyAudio
