low pass filter for DSD
Old 29th March 2019, 01:04 AM   #171
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Because you're now using a step-up transformer, the primary shunt inductance is going to be lower. So the cap before the trafo should be bigger - I think try 3300uF.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 29th March 2019, 07:14 AM   #172
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
I don't have on han 3300uF but can parallel several 1000uF to get 3000 or 4000uF, wich one better?
How do you calculate the shunt inductance?
Old 29th March 2019, 12:12 PM   #173
abraxalito's Avatar
I'd go for 3 * 1000uF. Shunt inductance is measured rather than calculated.
Old 29th March 2019, 12:41 PM   #174
Thank you.
Old 16th April 2019, 05:00 PM   #175
powerpz is offline powerpz  Bulgaria
Did somebody else tried low pass LCLC ? I did, but there is a lot of noise, more than signal.. I tried also first schematic R-C --> 3.3k , 1nF again the same ?!
Old 17th April 2019, 12:51 PM   #176
I am wondering if I need to reprogram firmware on Amanero 384 pcb with "DSD only firmware", to use direct connection to pin 3,5 - DSD1 and DSD2, because they are multiplexing with I2S data and clock
Think that merlin el mago can say
Old 18th April 2019, 08:13 PM   #177
I don't remember exactly the firmware of Amanero but isn't the latest beta. I can tell you because the computer laptop was gone.
Old 19th April 2019, 11:44 PM   #178
you mean that you didn't change the firmware and use as is?
Unfortunately Ive got chinese clone, and it is dead now, amanero flashing utility cannot recognize PID and DID and refuse to program it after erasing
And I didn't expect that I am buying the clone
Old 20th April 2019, 09:55 AM   #179
No. I changed the firmware only for DSD, I'm using Daphile as player so Linux based.
Try this one:
firmware 2005be & Cpld_for_1081
If doesn't works for you, try this other:
firmware_1099c & cpld_for_1080
If your board is a chinese clon start with firmware 1099c
Old 14th May 2019, 02:40 PM   #180
@ abraxalito
I want to use the 1:1 OPT for a gain of 6dB (attached pic), could still use your filter without modification?
low pass filter for DSDHide this!Advertise here!
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Low pass filter help ifrythings Subwoofers 1 24th February 2006 09:45 AM
Low Pass filter ThSpeakerDude88 Everything Else 4 8th November 2005 02:53 AM
low pass filter crazyant Car Audio 3 15th September 2005 06:15 PM
Copyright ©1999-2019 diyAudio
