Using the AD844 as an I/V
Old 13th July 2016, 10:39 AM   #1741
esgigt is offline esgigt  Netherlands
Originally Posted by Torchwood421 View Post
Hi esgigt, Keep us posted on your progress.
So I will.
Yesterday I finally found the time to perform surgery on my CD player, a CD880.
Among the NE5532 opamps I exchanged for the AD826's (and sockets!) also other work was done. Decoupling by chokes instead of resistors, increased caps (Vrefs of the TDA1541A S1 now have 3300uf muse gold caps) and a DEM-mod (thanks to the excellent thread by John of ECdesigns).
I choose the approach of listening, implementing a single mod and listening again and kept record of my findings.
Work sequence:
1) SAA7220 powersupply modded. Cleaned up some mess and relaxed the soundimage somewhat.
2) DEM-mod. Added more subtility and detail to the soundimage.
3) Power supply TDA. Losing some of the harshness and a more coherent sound image.
4) AD826. Game changer... soundimage now is dynamic, relaxed and "analogue", no harshness at all.
Old 13th July 2016, 03:15 PM   #1742
Torchwood421 is offline Torchwood421  United States
Thumbs up CD upgrades...
Originally Posted by esgigt View Post
So I will.
Work sequence:
Hi esgigt, That is excellent. Make a change and then a listen. That is what I do as well. John ECDesign's has done use all a great service. I use his decoupling method. John actually moved away from locking the DEM to the bitclock. Myself I use 120 pF between pin 16 and 17. That puts the DEM at 705 Khz, and that will sync up with the bitclock. However there is nothing wrong with his earlier DEM mod. Power supply is critical because the SAA7220 is actually rather poor. Sadly the only game in town in a CD player. AD826's are an excellent choice. I'd let things kind of settle in before making any other changes. Enjoy!
Old 13th July 2016, 03:49 PM   #1743
That's the plan, Torchwood... later the TWTMC will join the setup.. but I'll have to make some arrangements for it's power supply. Also the mute-transistors will go, but I didn't like to disassemble the machine yet, otherwise I can't reach them.
Had to demolish the 5532's too because they were hard to desolder.
In the meantime i'll have to solve a grounding hick-up in the pre-amp
Old 13th July 2016, 06:37 PM   #1744
Talking TWTMC?
TWTMC? Yes... The easy way is to clip the op amps out and unsolder each pin one at a time, that will prevent the traces from lifting as well. A 5532 isn't by today's standards state of the art so don't sweat that. Sorry to hear about the grounding issue. I have been there.
Old 14th July 2016, 08:41 AM   #1745
didiet78 is offline didiet78  Indonesia
SD Card Wav Player + AD1860 + DDNF
Didiet
Usb I2S + AK4490 / WM8805+ESS9023 / SDHC Card I2S audio player + AD1860
Old 14th July 2016, 08:51 AM   #1746
sumotan is offline sumotan  Indonesia
Nice Didiet
May I ask is the SD card player a diy effort ?
Thks
Old 14th July 2016, 09:03 AM   #1747
Originally Posted by Jaffrie View Post
Nice Didiet
Thks
Yes, it diy. Its based on Koon player. He make a thread about it.
Didiet
Old 14th July 2016, 06:24 PM   #1748
Thumbs up Very nice...
Something I should look into as well. SD card storage is rather interesting. Thanks for posting your player. Nice work!
Old 15th July 2016, 03:05 AM   #1749
Thumbs up Found it...
http://www.diyaudio.com/forums/digit...scillator.html A low jitter clock.
Old 16th July 2016, 10:57 AM   #1750
giro1991 is offline giro1991  Scotland
giro1991's Avatar
Eh, I think the point was missed completely.
When transistor is overdriven, the wave clips (approaches squarewaves).
I presume VFB OpAmps do this. What about current mirror section on 844 OPAmps though? Does it show 'gradual' non linear distortion when driven to extreme, similar to some certain tubes do? Apologies I was not clear enough earlier in my question.
Michael Gerzon's Trifield decoder: foobar2000 plugin - free
Cheap 20bit ladder dac with 4 fs minimum phase (IIR) filter TDA1306.pdf
Using the AD844 as an I/VHide this!Advertise here!
AD844 as a common base stage in the I/V converter Pedja Digital Source 44 14th September 2015 10:10 AM
WTB AD844 Opamps apassgear Swap Meet 6 31st January 2007 02:57 PM
Copyright ©1999-2019 diyAudio
