A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 18th February 2020, 10:21 AM   #7661
Smartdriver is offline Smartdriver  Netherlands
Originally Posted by smooth dancer View Post
Just have to try out theese ridicilous expencive resistors. They shall replace the Shinko I/V resistors. I hope it will pay off.
It will, i have them but you should have bought the 2W version. They sound even better then the 0.5W
Old 18th February 2020, 11:29 AM   #7662
smooth dancer is offline smooth dancer  Norway
Hmmm...are you sure, have you tried both versions ? Original is 0.5 watt.
And 2w silver tantalum is over dobbel the price, which is already high enough for the 0.5w.
Old 18th February 2020, 02:58 PM   #7663
To be honest, no i haven't tried the 0.5W but it was recommended to me by someone who knows his stuff but doesn't sell them.
With a non commercial biased answer i thought i did the right thing then.
Ouch, i see you talk about the silver version.....i have bought the non magnetic Tantalum version
Old 18th February 2020, 03:09 PM   #7664
I see. I think that it’s more important that the resistors is non magnetic and conten tantalum and pure silver.
Old 21st February 2020, 04:24 AM   #7665
I have been playing with the silver tants last evening, and this is very promising.
Old 21st February 2020, 12:41 PM   #7666
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello Norway,
When i was looking for a resistor to use at that spot i could only found the Shinkoh 2 watt. If i remember well the Audio note resistors available at that time were not the right the value for a 4 deck dddac. The new series have a 2 watt in that value?
I remember buying a few of these two watt resistors for a phonostage that was build by me. It was a pretty hefty invoice for la handful of resistors.
I remember buying the original Shinko 0,5 watt resistors in Paris 3 decades ago for less than 2$. These were considered expensive at the time.
So after finishing my new tiny power amp, going Fifopi, new clocks, lifepo4, supercaps i might try these 2 watts too.
Greetings, Eduard
P.s the attachment is a new copper chassis, 440*440*68 mm ( this is the power supply part including the ultra path caps. The signal part is 440*193*68 and will the attached to the bigger part by means of a wooden frame.
Old 21st February 2020, 05:29 PM   #7667
leifchristensen is offline leifchristensen  Norway
I was told that the 2 watts have their legs fixed in another manner, which highly affects the sound in a very positive way
Im not gonna spend a lot on mediocre tants if a can obtain better sound by spending a hell of a lot....
Old 21st February 2020, 09:13 PM   #7668
Nightpuma is offline Nightpuma  Norway
When talking about I/V resistors. Have anyone of you tried these: General Resistance GG102 Squaristor Series | Rhopoint Components
Old 21st February 2020, 10:44 PM   #7669
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally Posted by eduard View Post
Hello Norway,
Greetings, Eduard
Chassis looks awesome. Did they laser cut or punch it?
Edit, I can see they punched it.
TCD
Old 21st February 2020, 10:49 PM   #7670
Brumjam is offline Brumjam  United Kingdom
These were the best resistors I heard but not cheap. Then I upgraded to four boards and cant bring myself to order them again....minimum order quantity is 10 last I checked.
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
