A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 14th March 2019, 08:59 AM   #6771
vega65 is offline vega65  Norway
Originally Posted by dddac View Post
Actually I went to Lundahl as well with my expectations of bandwidth, maximum output voltage and the fact there must be room for some residual DC current, and the answer was they could not do it. Sowter could and the transformer is pretty high spec, so worth the Money. Of course other transformers will work as well, but most likely will not meet the expectations of high bandwidth in both ways and low distortion at high voltage Output. Do not forget, the Sowter does pimp up to 4,6 Volts rms
As the thread is quite long, I guess most questions (like mine) already have been answered...digging for them takes some time though...
I mailled Per Lundahl and asked about the ll1690 and ll7903 and dc tolerance to be sure they are not suited. Awaiting his answer as he is off a few days.
Old 14th March 2019, 09:33 AM   #6772
Originally Posted by mbrennwa View Post
Buuuut... on your photo, the box in the middle seems to be some kind of volume control / attenuator. Why don't you use a TVC (transformer volume control)? This would work as a transformer output for the DAC and a "lossless" volume control at the same time.
when I wrote "the box..." I was referring to the volume control It's a really really nice Tribute autoformer with taps, but as a singel coil not useable in the position discussed .
BTW Sowter recommends to put the I/V resistor on the secondary side, but it seems the DDDac with Cinemag is connected with I/V resistors on board: what's preferred ?
Old 14th March 2019, 04:18 PM   #6773
dddac is offline dddac  Germany
The I/V resisters are also used for DC bias, so please NO experiments without the four load resistors at the DAC output
www.dddac.com
Happy listening and building
Old 14th March 2019, 05:28 PM   #6774
Aye Captain!
My complements on your achievements with DDDAC!
The dc measure btw 0,4mV and 1.9mV between neg and pos. I was offered to borrow a pair of Sowter 1465's , will do some testing with them, and then order a pair of custom transformers tailored for my setup. ( assuming I prefer the trafo route).
Old 14th March 2019, 06:30 PM   #6775
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
...assuming I prefer the trafo route
As long your trafos are not broken and fit the DDDAC design, you will prefer them over the single ended cap output.
Old 16th March 2019, 01:53 AM   #6776
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
Got a heavy package today from Sweden. New choke and new power transformer ( still in box)
Greetings, Eduard
Old 18th March 2019, 09:38 AM   #6777
Andreas Thulin is offline Andreas Thulin
Hi, is this update only to do with the power supplied to the WaveIO board or will it also benefit if one uses a different I2S source (i use an RPi with Digi+Pro) which does not take power from the DAC mainboard?
Andreas
Originally Posted by smooth dancer View Post
Fantastic upgrade !!!
Replaced LF-50 regulator on mainboard with LT-3045. If you want to take a huge step forward, donít hesitate, just do it.
Old 18th March 2019, 10:41 AM   #6778
Originally Posted by eduard View Post
Hello,
Greetings, Eduard
looking forward to your "before-after" review Eduard
www.dddac.com
Old 18th March 2019, 10:44 AM   #6779
Andreas
Nope, not only Waveio - all 5Volt (!) SMD IC's on the mainboard are powered with this regulator - check the Circuit diagram I share on the download part of my website
www.dddac.com
Old 18th March 2019, 11:46 AM   #6780
NIXIE62 is offline NIXIE62  Serbia
Originally Posted by juancho View Post
Here's mine. Seven power supplies, three chokes, valve output stage, reclocker and four boards.its been tidied up since the pic! Sounds phenomenal and has seen some very heavyweight competition!Attachment 715525
If it's not a secret, what output tube stage did you use? Broskie cathode follower?
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
Copyright ©1999-2019 diyAudio
