A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 12th November 2018, 11:27 AM   #6711
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally Posted by abraxalito View Post
I feel fairly sure that an I/V using a CFP for an input stage (as the Legato does) should easily be able to get down to 1ohm, perhaps even lower. Using a common-base stage though does have practical limits though in terms of voltage transformation, I've found somewhere in the realm of 200X is a practical maximum - meaning if the input impedance is 1ohm, the output can't be more than 200ohm.
The 1794 is ideal for open loop I-V as you describe. Because it has such high
OP Z and is tolerant to OP swing, the distortion can be made very low.
I have simulated open loop I-V's for 1794, even without any local CFP type
FB that get a lot better than -120dB distortion. Obviously the sim is ideal and
usually optimistic but it does give some indication of the potential.
T
Old 12th November 2018, 12:13 PM   #6712
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Thanks Terry, very interesting info in that link.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 13th November 2018, 03:32 AM   #6713
The amazing thing is, he achieved such good results with everything hanging
off a breadboard LoL.
I'm quite sure the high Z current source OP really helps here.... read - don't
try this with a Sabre
Old 13th November 2018, 05:22 AM   #6714
abraxalito's Avatar
Ha well I'm also a fan of DACs with hiZ current source outputs. I just recently very crudely measured my TDA1387 and found its most likely over 1Mohm and also I get great results on a breadboard
Old 13th November 2018, 01:15 PM   #6715
NIXIE62 is offline NIXIE62  Serbia
This is my version of dddac 1794 (4 boards) with Nixie frequency display made about 6 months ago. Motherboard and supply are modified so that everything fits horizontally and the height is just 65mm. I do not think anyone has a Nixie display on a DAC, maybe I'm wrong. It looks much more beautiful in nature than on photos. I will probably replace the front panel in the future for something nicer, this one is only plasticized and printed with an UV printer. I do not care much for the look and the sound is phenomenal. Done with a little help from my friends.
Old 14th November 2018, 01:44 PM   #6716
juancho is offline juancho  United Kingdom
Here's mine. Seven power supplies, three chokes, valve output stage, reclocker and four boards.its been tidied up since the pic! Sounds phenomenal and has seen some very heavyweight competition!IMG_20181009_112942.jpeg
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 05:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 01:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 04:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
