A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 3rd November 2018, 04:03 AM   #6691
bohun is offline bohun
Default New build - no sound
I just built my first deck (7 more to go) and mainboard. Unfortunately, there is no sound whatsoever. Any troubleshooting tips would be appreciated,
Old 3rd November 2018, 04:09 AM   #6692
I Just build first dac board and Mainboard. Unfortunately there is no sound whatsoever.
I checked voltage in 12V, trimmer adjusted to 40mv.
Any troubleshooting tips would be appreciated.
Old 3rd November 2018, 09:57 AM   #6693
dddac is offline dddac  Germany
First to check
Did you connect the switch spdif / I2s ?
What DC value do you measure on POS and NEG versus COMMON ?
If all ok, than see if your source is really outputting I2S signals ?
www.dddac.com
Happy listening and building
Old 3rd November 2018, 03:41 PM   #6694
Thank you for responses: once I connected switch I was able to play music
I have tried SPDIF with Digi One Pro as well as RPI + Isoltaor and Kali. Sounds really good with 45/2A3 setup. Let the experiments Begin.
Old 4th November 2018, 03:08 AM   #6695
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Seems like you have a great journey ahead. Enjoy!
Support the Monkey Coffin!
Old 9th November 2018, 07:11 PM   #6696
steefdebruijn is online now steefdebruijn  Netherlands
About output options, would this active I/V be a good idea for this DAC? I assume to remove output resistors and capacitor on mainboard.
Can use both rca and balanced out on this if I read correctly
The Legato Discrete Balanced I/V Stage
Old 10th November 2018, 06:52 AM   #6697
I would say no, it defeats the concept of the passive I/V, which is totally linear and has no disadvantage over a complex piece of electronics doing basically the same
what do want to gain here ?
www.dddac.com
Old 10th November 2018, 07:02 AM   #6698
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Since you're asking let's see - its not just about the linearity of the I/V stage its also about that of the DAC. Best linearity of DACs in general is obtained when the output voltage is held constant. Could be that the PCM1794 is an exception to the rule though.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 10th November 2018, 07:48 AM   #6699
batteryman is offline batteryman  United Kingdom
I like the sound of my Sowter I/V transformers and am just turned off by the thought of more active devices between dac chip and amp. I'm also not taken in by the latest "state of the art" opamps as high spec does not guarantee the best sound. They are the product of rivalry between the semiconductor manufacturers imho.
Old 10th November 2018, 10:10 AM   #6700
MagicBus is offline MagicBus  Greece
MagicBus's Avatar
Does anybody know what is the input impedance of this I/V stage?
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 05:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 01:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 04:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
