A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 17th August 2014, 03:14 PM   #2481
nige2000 is offline nige2000  Ireland
Originally Posted by Almeg69 View Post
I have been altering the value of the output filter capacitors, What is the largest value allowed ? The recommended value of 5 - 10 nf per stack, can this be increased to 20 or 30nf per stack ?
Thanks, Alex.
Been doing lots of reading on that hf cap
Haven't done any experiments yet
But from what I read it really is subject to testing
But would have thought up to 30 pf would be in range for testing
Many values will need to be tested as most of them will have a neg to no effect for sq due to a small window
Old 17th August 2014, 04:47 PM   #2482
stijn001 is offline stijn001  Netherlands
stijn001's Avatar
Alex, 4.7-10nf per "board"..., i.e. a stack implies multiple boards. In my case I have four boards and used 22nf, which is pretty conservative.
Old 17th August 2014, 04:58 PM   #2483
Almeg69 is offline Almeg69  United Kingdom
I am using Vishay 1822 100v 100nf with 11 dac boards.
I want to try extra capacitance as increasing the value helps with resolution, ambience and purer treble. I do not want to damage anything by going too high a value ....
Thanks, Alex.
Old 17th August 2014, 05:18 PM   #2484
stijn001's Avatar
You effectively creating a low pass filter, the only thing you’ll eventually damage is the high frequencies when you get into the audible range..
Old 17th August 2014, 05:29 PM   #2485
Good news, I think the roll off is 100khz for 5nf and 50khz for 10nf so if I go too far I will limit the HF response only but not damage the dac boards :-)
Thanks, Alex.
Old 17th August 2014, 06:02 PM   #2486
dddac is offline dddac  Germany
The larger they get, the lower the HF cut off.... It is a simple 6dB/Octave low pas filter with the Rload.... so easy to calculate.... my recommendation causes a 3dB Point between 50 and 100kHz... It is very arbitrary and just pick what you like best
www.dddac.com
Happy listening and building
Old 17th August 2014, 06:17 PM   #2487
Thanks Doede,
I will keep it below 600 nf. Cut off 22khz ....
Thanks, Alex.
Old 18th August 2014, 12:25 AM   #2488
This might be of interest for the pos neg cap
http://www.diyaudio.com/forums/loung...technique.html
Old 18th August 2014, 05:31 AM   #2489
Hi Nige2000,
Can you elaborate a bit more what you are trying to do with the split resistors on the Outputs? The Rload value was determined to be 133 Ohm, you seem to be far off with that which will increase THD (when larger) or reduce the Output voltage at 0dBFS when lower
What are the improvements you indicated? Did you measure anything you can share?
Thanks!
www.dddac.com
Old 18th August 2014, 05:31 AM   #2490
Thanks Doede,
not per Deck of course
www.dddac.com
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
Copyright ©1999-2019 diyAudio
