A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 4th April 2014, 04:53 PM   #1451
rhlauranna is offline rhlauranna  Germany
ACvB, congratulations, this looks really cool...
could you please tell me about the superb looking enclosure, where did you got that ? and how much.... ?
thanks
Old 4th April 2014, 05:48 PM   #1452
ACvB is offline ACvB
Hi, the idea is from WalterW, it's the modu Galaxy Maggiorato GX388 330 x 280 mm, I found on post 881, 885, and 896. I also order feet and a special 10mm front. This give some problem with the tumbler switch because the thread of the switch is 9 mm, this had to be solved yet. I used 4mm under the main board and 7 mm between mainboard and first deck to keep the high below 80mm. I used to solder one red capacitor a little bit aslope to avoid contact with a solder above, better use 8 mm. It's rather expansive but it's a nice case: feet, extra front and transport 106 Euro, order at ELTIM audio BV, Europe's main supplier of original MOREL drive units and related products., gr, AcvB
Old 4th April 2014, 07:32 PM   #1453
WalterW is offline WalterW  Netherlands
Thanks! Never heard of them, I always ordered direct at the source in Italy
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 4th April 2014, 09:27 PM   #1454
very nice !!! thanks to you both...
Old 4th April 2014, 09:40 PM   #1455
rickmcinnis is offline rickmcinnis  United States
Default Not at all what I meant ...
Originally Posted by dddac View Post
there is a version available now with spdif....is that what you mean? check the web site sales section and download section, and the previous posts...
I have the original board.
I have no interest in using the SPDIF input.
I might go with eight DAC boards in the future,
Would it be worthwhile to go ahead and get the new motherboard?
I have been working on a new phono stage so have done nothing with the DAC from when I first assembled and it did not work. Wondering if I should start with the new board sine I am basically starting over.
Trying to get absolute clarification on how to use the new board. Is it ONLY for those who want the SPDIF input?
Thanks,
Old 4th April 2014, 09:45 PM   #1456
SimonJ is offline SimonJ  United Kingdom
If you are not interested in SPDIF you don't need the new motherboard
Old 4th April 2014, 09:48 PM   #1457
I am using the same case as Walter too and just got the front and back panels back after milling etc
Old 5th April 2014, 06:29 AM   #1458
I am curious, pictures please....
Old 5th April 2014, 08:17 AM   #1459
Here you go.....
Old 5th April 2014, 08:22 AM   #1460
G600 is offline G600  France
Another very nice case !
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
Copyright ©1999-2019 diyAudio
