Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#3521 |
Because of processing with high slopes you will have some small spikes in signal. You can try to post gain but on some material it will fire clipping notification.
#3522 |
@fluid: then the question is, why there are two gains at all: if we are only allowed to diminuish, this could be done with pre-gain alone.....
![]() @shining31: maybe minidsp has an advantage (only this one! ![]() But: what is enough? - Noone knows, how much gain the user wants for his deep bass frequencies. So, giving responsibility to the user might not even be a disadvantage. |
#3523 |
If by advantage you mean "dumber", then yes. Such is the risk of putting out a product with many tweakabilities and flexibilities: not everyone (i.e., very few) will appreciate it all. However, Nick's caveat still applies to miniDSP. Gain staging is simply about using the available dynamic range to maximum benefit. Nick was mindful to include physical LED indicators as well as graphical indicators in NUC to alert the user to clipping.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#3524 | |
If the signal is represented as a floating point number in the DSP the headroom is effectively unlimited for audio purposes. If / when it is converted back to integer as it must the gain will have to be reduced to avoid clipping. |
#3525 |
@shaun: you did not quote to the end: I think we share a similar opinion about miniDSP, but I expressed it a bit "milder".
![]() @fluid: O. K., I was just wondering, but I live with this for years and will continue. It´s not a real problem. |
#3526 |
I accidentally removed of the opamps while the najda unit was still powered on.
Now the unit still powers on but the volume control is no longer working. The output is distorted but can still hear the music pass through but with constant pops every couple of seconds. Adjusting the volume doesnt change the actual outputted volume. Ive confirmed its not the opamps being the issue. Im suspecting it is just the cs3318 chip (and nothing else). Is there a way i can confirm this? Annoyed with myself for being careless! 😓 Thanks in advance. |
#3527 |
If you have the capability, you could probe the input (individually) of the volume control chip. If the signal reaches there intact, you'll know the problem lies downstream. Inserting or removing a component while live can cause damage. In this case, the op amps are powered from a higher voltage than the digital chips. The act of removing an op amp under power can result in an arbitrarily harmful voltage being fed to the neighbouring circuitry.
#3528 | |
The 5v polarity was switched inadvertently ![]() Perhaps one good board could be made out of them both? I have a new board and a spare one in case that dies ![]() |
#3529 | |
Check one from the attachment. Info from charpaK recieved then "This small inductor is rated for roughly 0.4 A and will fry if the current exceeds that value - typically a short circuit - so it acts also as a fuse. Not a big problem! Replacing that part will fix the issue." This is one I have used as replacement LQH43MN220K03L MURATA Inductor: wire; SMD; 1812; 22uH; 320mA; 0.94Ω; ±10%; 4.5x3.2x2.6mm Last edited by jbator; 10th February 2021 at 04:17 PM. |
#3530 |
I had the same problem. I also changed the inductance (same reference) which had completely melted.
nounouchet |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
DSP Xover project | chaparK | Digital Line Level | 141 | 3rd July 2011 11:16 AM |
Help Please for simple active Xover project | dcathro | Analog Line Level | 4 | 9th September 2010 06:47 AM |
Violet DSP Evolution - an Open Baffle Project | cuibono | Multi-Way | 211 | 18th May 2010 03:26 AM |
Software digital DSP ... Xover/filters/EQ ?? | JinMTVT | Digital Source | 2 | 8th October 2004 07:02 AM |
DSP card & proper xover for heathkit 859A speaker cabinet | x. onasis | Multi-Way | 6 | 22nd April 2003 08:39 PM |
New To Site? | Need Help? |
