Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#3511 | |
This is Josh from germany and i am a newbie with my Najda. You wrote „firmware 1.3“ - is it correct, or do you mean the board version ? Thanks |
#3512 | |
![]() Quote:
Can you supply my with firmware version 1.3 ? Thanks Josh |
#3513 | |
WAF-Audio When you run NUC it will detect the firmware version and then update it if necessary.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| Last edited by Shaun; 13th January 2021 at 08:19 PM. |
#3514 |
Just to clarify: it seems that the firmware update resides within the NUC application.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#3515 | |
Don´t worry, I stream, too, but since I realized that I sold my turntable too early, I keep my ReVox tape deck and my CD-player. Why sell for nearly nothing? ![]() Thanks for the link to that article, nice to read with a cup of tea and cake - but I knew what impedance is. My (rethorical) question was how to solve the problem in the real world of Najda analog-in. I have measured the balance via S/P-DIF, everything o.k., seems to be a room reflection that I underestimated. ![]() Any idea why a positive post-gain "is the clue of an improper gain structure", as Nick wrote? |
#3516 | |
#3517 |
@jbator: Yes, I know how to workaround practically. It is only a question of interest, why Nick wrote this - or in other words: why not correct via positive post-gain?
#3518 |
The point he was trying to make is that adding gain back afterwards suggests you took too much away in the first place, therefore bad gain structure.
#3520 |
Do you have guys explanations on that? I don't understand why with thé minidsp I don't have to lower thé input signal to avoid clipping when I add a high-pass for examole
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
DSP Xover project | chaparK | Digital Line Level | 141 | 3rd July 2011 11:16 AM |
Help Please for simple active Xover project | dcathro | Analog Line Level | 4 | 9th September 2010 06:47 AM |
Violet DSP Evolution - an Open Baffle Project | cuibono | Multi-Way | 211 | 18th May 2010 03:26 AM |
Software digital DSP ... Xover/filters/EQ ?? | JinMTVT | Digital Source | 2 | 8th October 2004 07:02 AM |
DSP card & proper xover for heathkit 859A speaker cabinet | x. onasis | Multi-Way | 6 | 22nd April 2003 08:39 PM |
New To Site? | Need Help? |
