Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 13th August 2020, 04:15 AM   #2141
Alex_twn is offline Alex_twn  Taiwan
Thanks for the update.
On my side I completed the integration of your modified SEN based on 2SK2145 with a PCM1792A and it works very well.
Those JFET are still available so I have one question for you, why not pursuing in this way with JFETs available?
Old 13th August 2020, 04:28 AM   #2142
EUVL is offline EUVL  Europe
Everyone can build a SEN with multiple 2SK2145's in parallel.
So nothing new that needs my attention.
Patrick
xen-audio.com
Old 13th August 2020, 03:22 PM   #2143
samoloko is offline samoloko  Bulgaria
I have pcm1794 based dac using OPA1611 /12
It Is better than NE5534 / 32 but would like very much to see your Implementation with Sen
Old 18th August 2020, 05:35 AM   #2144
It is not very complex, I use the SEN principle & schematics and replace the original JFET by 2SK2145 with 2x SK2145 JFET in parallel to accommodate the current delivered by the PCM1794.
It is in the end equivalent to 4x JFET as each 2SK2145 include 2x JFET.
I am using a mono configuration and summing the output of the DAC so the output current is x2 on my side but with a stereo configuration and only 7.8mApp output current, most likely one 2SK2145 is enough per branch (no need to put 2 in parallel).
I have been sorting all the 2SK2145 I have to couple them in the best way. I am using a heatsink to thermally couple them.
Old 18th August 2020, 06:06 AM   #2145
With 7.8mApp current, I would be using 16mA bias at least.
That already means 2x 2SK2145BL in parallel.
But 2SK2145BL, even with 9V across it, dissipates close to 100mW per FET.
Too close to max. allowable dissipation for me.
Which means 4x 2SK2145GR in parallel, with matched Idss.
At least that is what I would do.
But of course you have it working with 2x //.
Which is what counts.
Patrick
xen-audio.com
Old 19th August 2020, 01:48 AM   #2146
ggetzoff is offline ggetzoff  United States
ggetzoff's Avatar
Originally Posted by EUVL View Post
After 9 years and 2000+ posts, people are still asking for PCBs.
The bad news is that we have none left, and cannot provide JFET sets.
The good news is that we are working on something new along the line of this :
When proven successful, we shall publish in a new thread.
Thank you for your interest,
Patrick
Patrick,
Thatís great, thanks for the heads up!
Greg
Airline Pilot-If it's not Boeing I'm not going.
Aleph J, F4, DCB1, VHEX +, USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece (sold) TDA1541A D3 with Abbas I/V, RH84
Old 16th September 2020, 05:10 AM   #2147
Alchamist is offline Alchamist
Alchamist's Avatar
Patrick
Anybody have SEN circuit with 2SK2145 ? It have Y, GR and BL models.Which one is ideal to make SEN ?
I plan to use it for balanced PCM1704 DAC.
Thank you.
Old 21st September 2020, 12:38 PM   #2148
Here you go :
A Simple Discrete Current-Mirror IV Converter, ŗ la AD844
Patrick
xen-audio.com
  Reply to this post
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
