Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Thread Tools
Old 24th October 2021, 10:09 PM   #7361
A123 is offline A123  United States
Originally Posted by kunlun121 View Post
I emailed sales at Skeleton’s tech asking them by when the SCI3400 would become available at the major wholesalers. This morning I received a reply that currently they are manufacturing these caps solely for large direct orders from industrial customers. He wrote that they “can't specify yet when we make it available for smaller quantities through wholesalers.” So nothing new there unfortunately.
I couldn’t help myself from asking what the MOQ would be. The answer probably won’t be useful to aspiring UcPure users, but who knows.
Latest news from Skeleton is that they can't do small quantities at this point. So that's a no to a direct order.
Cheers for making a attempt directly. Hopefully the threaded versions start populating on some distribution channels (primarily Mouser). But since they have demanding corporations and governments, the chances may be quite low.
Old 24th October 2021, 10:22 PM   #7362
I'm not sure what "too cutting edge" means. The SCI3400 has slightly better specs, but nothing shocking it seems. Ian's UcPure manual says: "Other 3000F/2.7V or higher capacitance/voltage ultracapacitors are also good for UcPure." That would imply that more "cutting edge" caps should work, but Ian would know better. Perhaps he'd like to comment.
Of course there are the Tecate caps that you mentioned, and the Eaton ones. Both look like reputable companies selling quality products. Personally, I am a sucker for that "made in Germany" thing but would not feel bad about using either of these.
I just meant the latest and greatest of their model, the 3400. The 3000 may have been out on the market longer. The 3400 may not even be released yet.
It's too bad, it would be my #1 choice too as German and European engineering is really appealing. I can't imagine how fast the Graphene will charge with the UcPure. If it takes an hour to fully charge a non-Graphene Ultra Capacitor, maybe a few minutes charge with Graphene? That would make a pretty robust solution.
I'm a good year behind in these Ian projects, so I may skip out on the UcPure as I just realised you need a third-party balancing board after skimming the manual. I just want to keep things simple for now and slowly learn. So I will try to hold out for Skeleton Technologies in late 2022. I have enough on my plate ATM to keep me occupied.
Old 24th October 2021, 10:34 PM   #7363
Originally Posted by iancanada View Post
Conclusions
5. I could be wrong, but my own experiences have shown that the sound quality of a OCXO with a multiplier is not as good as OCXO at the same finial frequency without a multiplier. I would suggest using the OCXO without multipliers as possible.
Ian
Thanks. Since I run exclusively Redbook on the RPi, the 5 MHz is all I will ever need along with the SinePi.
Old 25th October 2021, 01:39 PM   #7364
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by pz1 View Post
Hi Ian,
please, could you clarify the connection between miniLifoPo 3,3V and UC Conditioner 3,3V by diagram or picture?
I'll upgrade the LifePO4 Mini 3.3 user's manual for how to work with UcCondition 3.3 or UcHybrid 3.3.
Ian
Old 25th October 2021, 07:11 PM   #7365
pz1 is offline pz1  Netherlands
Originally Posted by Supersurfer View Post
Hi Paul,
You just need to connect one of the outputs of the lifepo4 to the input of the ucconditioner.
Than feed your circuit from the output of ucconditioner.
Hi Stefan,
Pretty clear, thanks.
Paul
Old 25th October 2021, 07:17 PM   #7366
Arnolddew is online now Arnolddew
Originally Posted by PinoNL View Post
I was thinking about that as well. Hopefully it’s possible to use that kind of XO’s
It's possible afaik. But i also wanted to know if the 3.3v regulators to the clocks can get bypased so only the clocks get 5v. Tentlabs seems to preform better on 5v. But maybe there are other sugestions. But not a lot people on this topic seems te be interested in this option.
Old 25th October 2021, 07:24 PM   #7367
iancanada's Avatar
You can feed 5V to FifoPi clean side if your clocks work at 5V, the rest of components are 5V tolerant.
Ian
Old 25th October 2021, 07:30 PM   #7368
Thanks Ian, same for Q2 i asume?
Old 25th October 2021, 08:10 PM   #7369
iancanada's Avatar
Q3 the same, just have make sure your XOs are 5V.
Ian
Old 25th October 2021, 08:14 PM   #7370
Q2 you mean. I have Q2 for now. Tanks anyway again.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
Thread Tools
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3312 17th November 2021 05:21 AM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1422 22nd March 2020 03:15 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 01:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 10:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
