Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Thread Tools
Old Today, 09:38 PM   #6481
Oneminde is offline Oneminde  Sweden
Oneminde's Avatar
Originally Posted by Dimdim View Post
I don't see a way for this board to be used for audio. It's just a USB-to-GPIO "adapter" - no relation whatsoever to I2S.
Well, the I2S or DATA, BCK and LR which is the I2S signal package comes via the output pins. This will happen if you are using any SBC (Single board computer) or S/PDF, USB or Ethernet converter. FIFO_PI needs the I2S package and don't care what source it is.
So therefore, using the RTK.GPIO would work - but internal USB to I2S is simpler.
In order to become sane in an insane world, you must first become insane.
Old Today, 10:16 PM   #6482
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by Oneminde View Post
Since I'm rather late to the party, what I bring up has probably been mentioned earlier. I know using a PC instead of a RPi has been mentioned and since the RPi has the unique GPIO interface which Ian is using for his products,
I wasn't sure how to interpret the use of a PC, you know, to fully bypass the RPi. So I found one.
Ryanteck RTk.GPIO
circa 12
Bring the world of physical computing to your PC or Mac by adding GPIO to your PC Or Mac with the Ryanteck RTk.GPIO!
The RTk.GPIO is a Plug & Play USB Device which adds 28 x Raspberry Pi style GPIO pins to your computer!
Compatible with Windows, Mac and Linux this board allows you to add GPIO to your computer.
The RTK GPIO board allows you to connect the world of physical computing to you desktop PC or laptop.
The RTK GPIO board emulates the original Raspberry Pi 40-pin GPIO header allowing you to program for the Raspberry Pi on your computer.
The board is fully compatible with Windows, Mac OS and Linux and supports a range of programming languages such as Python, Java and also use with Scratch.
The Ryanteck RTk.GPIO Features:
- Adds 28 GPIO to your computer
- Powered over USB
- Compatible with Windows, Mac & Linux
- Ideal for learning about electronics using real-world inputs & outputs.
- Use it to control LEDs, Add a LCD display to your computer, control a robot or more! (Example projects require other components to create.)
- Compatible with most Raspberry Pi add-ons that use GPIO, this device is ideal to use with your exsisting add-ons, HATs or pHATs.
- Compatible with Windows 7, 8 & 10. OSX 10.11, macOS 10.12, Ubuntu 16.04, Raspbian & other major linux distributions
Ryanteck/RTK.GPIO at master * PiSupply/Ryanteck * GitHub
What I envision is to use something like Gigabyte GA-J3455N-D3H or Supermicro X11SAAand internally connect the RTK.GPIO directly to an empty USB port on the motherboard.
This together with Ian's Reclocker platform and Andrea Mori clocks should be among the better options out there.
Any comments ??????
(Supermicro X11SAA is what Innuos is using)
You can use a BridgePi to work with a PC as a Pi free application.
DocumentDownload/Adapters/BridgePi at master * iancanada/DocumentDownload * GitHub
Ian
Old Today, 10:27 PM   #6483
Oneminde's Avatar
Right... Amanero USB, should be fine for the I2S. Thanks for reminding me
  Reply to this post
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
Thread Tools
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3307 6th May 2021 07:50 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1422 22nd March 2020 02:15 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
