XMOS-based Asynchronous USB to I2S interface
Old 22nd March 2020, 07:35 PM   #3241
UMarcus is offline UMarcus  Germany
I wrote him. Thx.
Old 23rd March 2020, 03:01 AM   #3242
aradan is offline aradan  Singapore
Originally Posted by aradan View Post
I apologize I have posted wrong contacts here. The above post by NickD is the correct one
Old 13th April 2020, 05:14 PM   #3243
Lorien is offline Lorien
If you have a WaveIO board you can email @Lorien via his website with a request. He responds pretty quickly.
Excepting those cases when I have to run away from Covid-19...
I wrote him. Thx.
Please check your email!
Stay healthy,
L
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 23rd April 2020, 10:07 PM   #3244
br20t is offline br20t  Poland
Latest drivers?
Old 1st May 2020, 01:15 PM   #3245
hulsebos is offline hulsebos  Netherlands
Hi Lorien,
I've just ordered a WaveIO board. Looking foreward to using it.
I have aquestion:
Can I directly drive the I2S pins of a PCM1794 DAC IC from the isolated I2S connector of the WaveIO board or is a buffer needed inbetween? The DAC IC will only be a few centimeters away from the WaveIO board.
Edo
Old 1st May 2020, 01:59 PM   #3246
Hello Edo,
order is confirmed, thank you! You can directly drive your DAC with WaveIO from isolated I2S port but you'll need to apply a 3.3Vdc power to the output side of the isolator between the V+ and any (or all) of the "Isol.GND" pins.
You can take that voltage from the digital side of your DAC but my advice is to find a small regulator like those who are replacing traditional 3 pin ones and wire its output directly to V+ and Isol.GND. Obviously, the Isol.GND pins are common with the digital GND of your DAC but NOT with the main GND of WaveIO! Any short circuit between WaveIO main GND and Isol.GND will defeat the isolation barrier!
I hope I was clear... if not simply ask or use the contact form.
Kind regards,
L
Old 1st May 2020, 03:37 PM   #3247
Hi Lorien,
Thanks for the quick reply, you were very clear
Edo
Old 1st July 2020, 05:44 PM   #3248
Raj1 is offline Raj1  United Kingdom
Originally Posted by Lorien View Post
Hello Edo,
Kind regards,
L
Hi Lorien,
Sent you an email requesting the latest driver and firmware. Not sure if you received it.
-Raja
Old 2nd July 2020, 07:01 AM   #3249
Got it! You should have the drivers by now!
Old 2nd July 2020, 02:05 PM   #3250
diyiggy is offline diyiggy
diyiggy's Avatar
Hi Lorien, I advised your board few time ago to a member but I didn't know about which NDK version you use today : is the best of the to still an option when ordering on your web site please ? Same isolator chip as before as well ?
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1422 22nd March 2020 02:15 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 07:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 03:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 02:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 10:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
