XMOS-based Asynchronous USB to I2S interface
Old 14th January 2019, 11:14 AM   #3201
Extreme_Boky is offline Extreme_Boky
Shorter return path would do better
Old 14th January 2019, 11:15 AM   #3202
deduikertjes is offline deduikertjes  Netherlands
deduikertjes's Avatar
But that gives ground loops as an added bonus. Or am I misunderstanding something?
Old 15th January 2019, 08:27 AM   #3203
Lorien is offline Lorien
The idea is to keep the short return paths since the digital I2S signals are 'fast' ones and I remember clearly that return path for these kind of signals is closest to their related "hot" wire. If you'll force them to take a bigger route just to avoid ground loops then it is possible to degrade their integrity (increase overshoots and ringing).
If you really want to keep a short path while avoid ground loops then I do recommend you to try out some stitching caps. of 100nF or so placed in series with the short ground path. Look here at page 10 and you will see what I mean.
L
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 15th January 2019, 01:59 PM   #3204
Ryelands is offline Ryelands  United Kingdom
Originally Posted by phi112358 View Post
Is it better to use a separate PSU if the DAC already has its own dedicated PSU?
Ever since I bought my first WaveIO in 2011, I have connected them to the DAC via the WaveIO's isolator chip using the DAC's +5v line. This called for a lead about 120mm long between the DAC and the isolator chip.
I don't know why recent attempts to connect the two directly via u.fl connectors failed but suspect an earthing issue given that the two devices have separate Uptone Audio LPS-1s set to 7v with LT3045 Vregs mounted as close as possible to the load. (The Meanwell SMPSs that drive the LPS-1s are connected to the mains via isolating transformers.)
On a whim, I recently tried fitting a 5v LDOvr LT3045-based Vreg directly to the isolator chip via short (10-15mm) leads and connecting the Vreg to the DAC's "raw" PS via carefully screened leads. In short, I now have one 5v Vreg for the DAC and another for the isolator chip.
The result was a very marked improvement in sound quality, more "transparent", better bass, all the usual stuff. In short, I don't think the isolator chip needs its own PS but it does greatly benefit from its own Vreg. A significant upgrade for an insignificant cost. Lorien is right.
Again, dammit.
HTH
D
Old 17th January 2019, 12:46 PM   #3205
chermann is offline chermann  Austria
Hi
After a long search for an "better" DAC i landed at Gustard A20H. I use this DAC over usb. Triggered from an other threat i try the first time a purifier (ifi nano iUSB 3.0)..first sound checks are promising...will see.
now my question:
can i expect a better SQ over an USB to I2S converter into my DAC ??
If yes which board or complete interface can you prvide me?
thanks you in advance
chris
Old 21st January 2019, 08:34 PM   #3206
Hi again
Sorry my ignorance to think that i get an easy answer. i start to read the first 60 pages ....my head is burning....
.. after read, learn and decide i will try an usb to I2S board to connect it...but this takes time
chris
Old 22nd January 2019, 09:17 PM   #3207
weissi is offline weissi  Austria
Chermann, in your case, owning a DAC with presumably well designed Xmos implementation and outfitted with possibly very good clocks, there is not much to be gained.
regards / servus
Old 23rd January 2019, 07:56 AM   #3208
Hi Weissi
i am very sorry for my nooby statements but i start since 1 year with diy....and with my mod of UD301 very nooby
as i read mor here in the digital line level i get more and more hungry for some future modifications (teac UD301)
Thank you for your positiv statement to my DAC which i got in 01/2017. after a journey of aune 16, Brooklyn, RME + Mutec 3...etc
chris
Old 1st April 2019, 04:29 PM   #3209
AlexanderTD is offline AlexanderTD  Ukraine
Hello there,
Tried to update firmware to DSD and got error message...
Update: Ah, i didn't find the right post in time - found everything needed in driver archive...
Old 1st April 2019, 06:05 PM   #3210
Can't get DSD playing with WaveIO V6.C7 firmware + 4.14 driver. Foobar is playing but no sound from my Buffalo DAC (SACD, DSD proxy, foo_dsd and all that installed). Tried Jriver but when set to bitstream output DSD a lound "white" noise is played.
If anyone used some sort of guide of how to setup players which worked and can share a link i'd be thankfull!
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1412 11th December 2019 03:56 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 08:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 04:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 03:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 11:34 AM
Copyright ©1999-2019 diyAudio
