XMOS-based Asynchronous USB to I2S interface
Old 16th November 2014, 10:35 AM   #2211
jrling is offline jrling  United Kingdom
Originally Posted by m.massimo View Post
2.24.0 works fine on my 0x0330 board.
That's good to hear.
Did you find any improvement in SQ compared to 2.23?
Cheers
Jonathan
Old 16th November 2014, 12:01 PM   #2212
m.massimo is offline m.massimo  Italy
Not listened carefully yet, just checked if it works.
Old 16th November 2014, 06:09 PM   #2213
I also have the 0330 board and sorry to say the install failed (multiple times). I uninstalled 2.23 first and trying installing 2.24 with and without the WaveIO turned on.
It is failing right at the end. The dialogue says it is copying the CPanel App and fails to copy. But it copies everything before that successfully.
Never had any problems installing Thesycon drivers before with the same PC/WS2012R2.
Lorien - would appreciate help.
Many thanks
Jonathan
Old 17th November 2014, 07:15 AM   #2214
sorry to hear that. I followed this path, uninstall 2.23, reboot, install 2.24 with WaveIO turned on, reboot, I got no problem on 8.1.
Is it ok if you reinstall 2.23?
Old 17th November 2014, 08:06 AM   #2215
Lorien is offline Lorien
@ Jonathan: I guess there are some changes to the driver installation procedure as well, like it was some versions before this one...and, once again, I'm a bit skeptical when it comes to this. On my side I tried these drivers on Win Vista, 7 and 8.1. If there were some errors or issues I would contact Thesycon immediately and not release this version as I have no gain in running into this kind of cases like yours and put WaveIO users on troubles!
Below is a list of supported Windows OSes taken directly from one of Thesycon documents. They mention Server variants as well! Like Massimo said before me, I kindly ask you to try again and see if there are any changes. I have to make sure that this is a driver issue or my stupidity 'in action' (as I customized those drivers... at some extent). If, indeed there's a driver problem, I'll forward it to Thesycon and ask for a solution.
Contact link for WaveIO USB-to-I2S/SPDIF board.
Old 17th November 2014, 10:49 AM   #2216
Tried installing 2.23 back and that failed in the same way. Error copying WaveIOks.inf file. So it must be something in my 2012R2 set-up as I had 2.23 installed before.
Old 18th November 2014, 09:19 PM   #2217
Jonathan, I'll come back to you in the following days with a second version of this new driver.. the unpacked one... like all the variants up to v2.23. Maybe there's a problem related to that archive, who knows! It will take some time as I have to build it from scratch!
Meanwhile I'll search for advices to Thesycon...
L
Old 21st November 2014, 06:23 AM   #2218
siginitz is offline siginitz  Germany
I think you have a problem with win 2012 R2. I have version 2.24 in win 2012 R2 . It installed without problems and is working fine.
Sigi
Old 21st November 2014, 10:27 AM   #2219
Sigi
Yes - I think so too. Strange though as I installed 2.23 before without issue, and haven't changed the set-up of 2012R2.
Have you noticed any SQ improvement with 2.24?
Jonathan
Old 22nd November 2014, 08:34 AM   #2220
@ Jonatha: you have PM.
Warm wishes,
L
XMOS-based Asynchronous USB to I2S interfaceHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1412 11th December 2019 03:56 PM
Introducing miniStreamer: Native 24/96 USB to I2S / SPDIF interface minidsp miniDSP 40 22nd October 2015 08:46 PM
Ultimate USB to I2S interface sampler Digital Source 206 30th January 2012 04:45 PM
Is it possible to develop a ASIO driver for PCM2900 based USB Audio interface? cxhawk Digital Source 7 3rd December 2010 03:30 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 11:34 AM
Copyright ©1999-2019 diyAudio
