Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Thread Tools |
#351 |
Thorp,
Interesting project. I don't know if its the best way to go in the end, but dacs of the type are are building can sometimes even sound a little more dynamic than the recording really is. On the other hand, SD dacs can sound bit flat in terms of perceived dynamics. There are ways to compensate both types of dacs for perceptually more natural sound. The question for me which type can produce a better overall sounding result with compensation/correction in place. Ultimately, I suspect a compensated SD dac will do better. Time will tell I guess. |
#352 |
How does one know a DAC to "sound a little more dynamic than the recording really is"... whats your reference?
More distortion to the people! Timing . . . . is paramount. |
#353 |
#354 |
DDDAC Audio
Thorp, not sure if you have the equipment to do a linearity test up to 24 bits, but if you want I can run that for you on my Audio Precision equipment.
for example, below is the linearity of the DDDAC 1794 - as you will see it is almost impossible to reach true 24 bit linearity ![]() This was actually a test I ran as some one mentioned the Vcom decoupling on the PCM1794 was not necessary. I proved him wrong as you can see ... Of course R2R dacs with non-laser trimmed resistors for LSBs and wanting to do 24 bit is quit a challenge, so checking this is a MUST so you know if you reached your design goals any way up to you ! |
#355 |
Thank you @dddac for your feedback.
Now I see your point: of course it is not a trully 24 bit dac! When I named that, I reffered to the "size" of R-2R ladder. This is a learning project, actually my goal is to (start) learn about FPGAs & CPLDs. I don't even have a modern RPi (but it will arrive today, the courier just called me ![]() It is just a hobby and, yes, you are right, I don't have any expensive equipment, but I wish to! ![]() On the other side, I am on your side: I also want to reach the best possible version of something I work to. Even if I believe that no one can hear any difference between "with 47uF" and "without 47uF", I still woluld do as you did! Perception can be subjective, but the numbers (math) don't lie, actually they are our common language. |
#356 |
DDDAC Audio
Indeed Thorp, doing what you did is a great learning process and I am very interested in your results. My offer stands, if you at any point feel it would be nice to have a Linearity, THD, Noise, Frequency transfer - measurement - straight from digital source to analog output, let me know
#357 | |
Btw you can get digital potentiometers that can be programmed via SPI etc, if you have a calibration step manually then use a digital to fine tune where human fingers can't. Love the DAC name btw ![]() Last edited by NickKUK; 5th December 2020 at 01:39 PM. |
#358 |
Hi, NickKUK, thank you for your feedback.
I agree, but unfortunately, it is hard to draw so many matched length wires on an RPi size PCB. Some FPGAs are already on the way: EP4CE22 in 16x16, 1 mm pitch balls - that means 17x17 mm sq. footprint, and EP4CE40 in 22x22 , 0.8 mm pitch balls - that means 19x19 mm sq. footprint. They are huge for such as small PCB size! More than that, I want to use them in combination with AK4137 - these ones already arrived -, so, it is hard to believe that I will be able to put all of them on the same RPi size PCB. At least because of the isolators, some hi-q IC flip-flops are mandatory, I am still looking for them. Anyway, at this moment, this project is in my mind only. I have finally managed today to compile my first functional kernel modules for Volumio! ![]() |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? | TonyDasilva | Digital Line Level | 21 | 13th April 2009 06:10 PM |
New To Site? | Need Help? |
