DAC gallery
DAC gallery
Old 19th August 2018, 08:00 PM   #301
grunf is offline grunf  Croatia
grunf's Avatar
This year I had a bit refreshed my old DAC, I / V conversion was changed from passive to ground grid, tubes are the same 6S4P, all CCS now have double FET instead of lower DN2540 in cascade and for all digital circuits except for PCM1702 voltage regulators are now ADP7118. High voltage power is a copy of the power supply from ARC LS25MKII.
Otherwise DAC is an old school CS8414-PMD100-2xPCM1702.
Old 28th August 2018, 08:59 PM   #302
grunf's Avatar
One 'small' upgrade
Otherwise, the DAC sounds great. One of the best 'analog' digital sources I've heard.
Old 29th August 2018, 04:31 PM   #303
wtnh is offline wtnh  United States
wtnh's Avatar
Default My piCorePlayer (Allo based)
I put together a piCorePlayer using a Hammond chassis. It has an official Raspberry Pi touchscreen and uses an Allo isolator between the Pi and the Allo Boss DAC. It also has LiPo batteries to power the isolator and DAC. The small board in the middle is a custom board I designed to host the +5 volt linear regulated supply and a charging circuit for the LiPos.
The display controller is underneath the batteries and is flopped down to a horizontal mounting position.
When the player is quiescent, the batteries are placed in parallel for charging and when active, in series for powering the isolator and DAC. The switching is done by 3 relays controlled by a GPIO pin on the Pi. When powering the DAC, the batteries are completely floating and therefore the DAC is galvanically isolated from the Pi power supply and ground.
The setup is currently running piCorePlayer 3.5 and LMS. It is driving a passive preamp which is connected to a McCormack DNA 0.5 and Martin Logan Aerius i's. It sounds very clean, particularly playing 24-bit FLACs and is dead silent between tracks. Having played with various DAC setups, I'm pretty happy with the battery solution.
I should mention that the physical design was inspired by Pascal Hibon, who posted some of his builds over in the Slimdevices forum.
Cheers
Whit
Old 1st October 2018, 12:29 AM   #304
Bigun is offline Bigun  Canada
Bigun's Avatar
DAC gallery
Whit - darn nice DAC you have there!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 1st October 2018, 01:45 AM   #305
wtnh's Avatar
Thanks! I regard this as a work in progress - sort of a learning experience. So far, I am pretty happy with the sound an usability of piCorePlayer on this hardware.
I plan to build other DACs with (possibly) better sound in the future.
Cheers
Whit
Old 11th January 2019, 04:05 PM   #306
wirescrossed is offline wirescrossed  United States
Default Earthquake cr-101
found this one awhile back..
Old 12th January 2019, 08:24 AM   #307
dddac is offline dddac  Germany
yep, nice museum piece, no question, but where is the DAC
www.dddac.com
Happy listening and building
Old 12th January 2019, 08:26 AM   #308
Cheers
Whit
I like what you did with the Vu-Meters I would like to see a video on how smooth the actually work? I have those on my Aurender and is sooo jerky, the might as well have left it away….
www.dddac.com
Old 3rd February 2019, 01:40 PM   #309
tru168 is offline tru168
Default DIY DAC
Hi ,
Just wish to share my DIY discrete 24 bit R2R DAC. I'm building another one with 18 or 20 bit because of matching resistors are virtually impossible for 24bit, but it sounds great with resistors I matched using 6-1/2 digit multimeter.
a simple video here,
YouTube
Old 3rd February 2019, 01:43 PM   #310
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Nice job!
Thorens TD-318/Ortofon Super OM 20, Teac VRDS-10, Buffalo II/NTD1, Allo DigiOne/Moode, UcD400, JBL 4313Ti
DAC galleryHide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Copyright ©1999-2019 diyAudio
