DAC gallery
DAC gallery
Old 28th April 2016, 02:33 AM   #211
rsthomas is offline rsthomas  United States
Where did you buy the enclosure from ?
Old 28th April 2016, 11:36 PM   #212
gaetan31 is offline gaetan31  New Zealand
Smile Love DIY
CS8416 +CS4398 + ECC88 or 6N6P Brosky un-balancer + PY82 HV PSU in CLCLCRC, all regulators are LM1085 or LM1086.
Since then, I have added an input micro switch at the back so I can switch between SPDIF RCA or Toslink (TORX147).
Old 9th July 2016, 09:35 AM   #213
boriss111 is offline boriss111  United Arab Emirates
Default My integrated DAC
This is my Toslink -> CS8416 -> SRC4192 -> WM8741 -> LL1527XL DAC.
The output from the transformers is fed directly to pair of Holton's HPA-nxV200L R4 amplifiers powered by pair of Audio Power DPS-400/S1 SMPSs.
Built in volume control from WM8741 is used via PIC controller.
Old 11th July 2016, 09:03 PM   #214
ragerino is offline ragerino  Austria
Originally Posted by rookakoma View Post
This is the DIYINHK AD1862 DAC kit with PSU boards.
The kit is very simple to build. I changed 4 alu elcos to tantal regarding the AD1862 datasheet. The dac is plug and play with my macs, and very comfy.
The sound is incredible, really.
Looks very interresing.
Thinking myself of getting a similar setup. Do you use it for DSD playback? Have you compared it to other DAC'?.
I'm currently using a Durio Sound Pro with my Raspberry PI2 and a Toroidal Transformer. Do you think there would be a siginifcant difference between your setup and a RPi-Dac?
My setup is:
Durio Sound Pro & Chromecast Audio
--> Mezmerize DCB1
--> Pavel Dudek Gainclone PA03 (soon with Burson Audio OpAmps instead of Burr Brown OPA134PA)
--> Q-Accoustics 1020/1030 speakers (soon DIY sepakers)
Old 11th July 2016, 10:40 PM   #215
Torchwood421 is offline Torchwood421  United States
Thumbs up PCM1704+DDNF+OPA627
Just sharing my recent build. I am using a Tekdevices WM8804 input receiver. I used the PCM1704 evaluation board schematic for the DF1704 and PCM1704 sections. I/V is a modified Pedja Rogic Discrete Diamond No Feedback stage. Omitted 2 mA current sources, changed I/V resistor to 2.5K Ohm and 470 pF Polystyrene capacitor. The OPA627 stage runs at a gain of 2 and operates as a voltage buffer for the DDNF I/V. Filter is passive based on Lundahl LL1690 line transformers wired as 2:1 step down. Build is outlined somewhat at the AD844 thread. Faceplate is African Paduk.
Old 11th July 2016, 10:41 PM   #216
Default PCM1704+DDNF+OPA627
A build photo.
Old 11th July 2016, 10:42 PM   #217
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Beautiful kitchen.
Old 11th July 2016, 10:43 PM   #218
No attempt was made to make this small!
Old 18th July 2016, 07:09 PM   #219
SS4927 is offline SS4927  Canada
SS4927's Avatar
Real nice work there and great choice on cases they remind me of two separate manufacturers over there. Gotta' like the minimal no frills looks outside/ beast inside.
Old 26th October 2016, 02:44 PM   #220
Giordano is offline Giordano  Hungary
my new dac, which is not just a DAC, it includes an RPI. SW is Moode Audio now, but I will try Rune Audio soon too.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
There are several things to do still, cable tie up etc., unfortunately the toroid has to be replaced too, it is noisy. I mean not in spread flux or electric noise, but without connecting an amp, in a silent room I can hear that. I need to replace and finish.
JG
DAC galleryHide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Copyright ©1999-2019 diyAudio
