ackoDAC based on ES9018
Thread Tools
Old 16th February 2011, 09:23 AM   #301
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by crazyfrog View Post
I read this thread with interest. Any experiment to share? I had in mind the Buffalo DAC but this one is interesting too...
i can tell you that everyone i know pretty much tat has one, also has the buffalo ii and myself and those i have talked with about it have designated the ackodac as the main rig to focus efforts on.
Old 24th February 2011, 01:02 AM   #302
acko is offline acko  Australia
Default System Build
Originally Posted by acko View Post
msjjr, fully boxed unit with all the modules. This is all shaping up now.
Cheers, Acko
AckoDAC Project
Old 3rd March 2011, 07:11 PM   #303
crazyfrog is offline crazyfrog  Canada
Default Firewire
I'm waiting for my DAC now .
Since I'm not an electronic expert, does someone have suggestions to fit a firewire (IEE1394) on?
Old 3rd March 2011, 07:19 PM   #304
Just want to say I know there are "firewire-usb" adaptors (and then to I2S input onboard) but is there a different way?
Old 4th March 2011, 02:30 AM   #305
qusp's Avatar
no, not possible and other than adapters will not ever be possible, firewire is dead in the water and will be phased out now that thunderbolt is available. do you have an old computer or something? i cant think of many computers that have firewire and not usb, any solution would end up costing as much as buying a used mac mini
Old 8th March 2011, 02:01 AM   #306
wrlco is offline wrlco  United States
I just found your forum. Is it still possible to order units, and if so, how much would the total package cost? I want to use a DCX2496 to tri-amp a set of horns. I assume I would need three units.
Thanks in advance for your help
wrlco
Old 8th March 2011, 03:15 AM   #307
qusp's Avatar
look at the website link in his sig, there are too many options to give you a price here
Old 9th March 2011, 05:40 PM   #308
fralippo is offline fralippo  Italy
I plan to build a 192/24 dac driven by async I2S usb interface soon. It seems as the es9012 ic is one of the best out there. As I want to use a tube I/V I fancily build I'm wondering what's the I/V resistor value range that the 9012 likes to see. Now I use 39R with the vintage Philips TDA1540 and TDA1541.
Old 9th March 2011, 09:06 PM   #309
qusp's Avatar
the 9012 does not like to see any iv resistor, the sabre requires almost zero impedance at its output to perform its best, passive iv with a resistor will shave about 30db off the dynamic range
Old 9th March 2011, 11:39 PM   #310
rolls is offline rolls  Switzerland
passive is possible with a suitable transformer with outstanding results, but a good transformer is not readily available and can be a very costly solution.
ackoDAC based on ES9018Hide this!Advertise here!
Thread Tools
DIY ESL III (based on an ER Audio Kit) jasonlky Planars & Exotics 10 3rd July 2017 07:04 AM
WM8816 based pre-amp panson_hk Chip Amps 13 22nd May 2009 03:16 PM
UCD based amp oldmaelstrom2 Class D 3 27th June 2007 11:10 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
