Opening the new DacMagic????
Old 29th December 2010, 11:10 PM   #101
Fatmangolf is offline Fatmangolf  United Kingdom
Originally Posted by stormsonic View Post
Capacitor swaping and opamp rolling is hardly called an "upgrade".
Do some real upgrade work, like fixing digital input, new power supplys for 74VHC153, 74VHC32, 74HCU04, 74HCT14...chips, or adleast isolate them. Get rid of noisy DC-DC switcher inside, make new regulator for clock supply, right now there are ripples over 100mV there
Make new analog section & new power supply for analog section and fix a lot of other things. Been there, done that.
The changes I made are modest compared to the more advanced work you have done but it does sound better than when I bought it, which makes it a mini-upgrade at least!
2 questions:
1) please can you post some details (or weblinks) for the advanced modifications you suggested for the DACMagic Azure?
2) which ones are worth doing for a CE unit like this?
Where is this DC coming from? From preamp coming back to DAC? Then your preamp is faulty.
Mine is fine thank you. But you can see why I suggested hooking up a VM before assuming the output caps aren't needed. Better safe than sorry.
Old 30th December 2010, 12:14 AM   #102
ggbaba is offline ggbaba  France
Thank you very much Fatmangolf and everyone for your precious help !!
Old 30th December 2010, 12:41 AM   #103
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Originally Posted by Fatmangolf View Post
This may be a daft question but is there any way we could reduce the loading on the NE5532's (or their replacements)?
Its not a daft question, but the solution will be quite a bit of rework on the board. There's a fairish number of 0204 Melf resistors to change in order to do this, and there'll be a slight noise penalty (maybe too small to notice).
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 30th December 2010, 12:29 PM   #104
MatchASM is offline MatchASM  Europe
...is there any way we could reduce the loading on the NE5532's (or their replacements)?
Depending on whether you want the RCA outputs or not, you could remove the OP275s and the 1k input resistors that surround them (R194,R195,R218,R219). This will decrease the loading to about 1k Ohm, but will also disable the RCA outputs.
Alternatively, as mentioned earlier, you could scale the resistors. I would suggest scaling R194,R195,R196,R197,R218,R219,R220,R221 to about 6k8. And then changing R182,R183,R190,R191,R206,R207,R214,R215 to 10k. This will bring the load down to 2k, while keeping the RCA output functionality. Don't bother with the capacitors, 10pF is nothing; I think they are there for yield purposes, just in case the amplifiers have a tendency to oscillate. In fact, the dacmagic might actually sound better with C283,C290,C320,C326 removed.
As for noise, I'm pretty sure the opamps will still determine the noise level.
If anyone does decide to go this way, good luck replacing 16 SMD resistors! I personally prefer replacing 4 dual op-amps.
Greetz,
MatchASM
Old 30th December 2010, 01:31 PM   #105
qusp is offline qusp  Australia
qusp's Avatar
you might want to try the OPA1642 as well, in the same vein as 1612, but better in every way. gotta love jfet input opamps
Old 30th December 2010, 02:37 PM   #106
I thought the OPA2141 was the state-of-the-art in JFET opamps...
Anyhow, I personally dislike JFET sound, and the high input impedance is not strictly needed here, since we're not building a phono preamp. So I would recommend replacing bipolar with bipolar.
But if you're a JFET fan, nothing stopping you from trying any of the OPA627/1642/2134/2141/2604 (or AD823, if you dislike TI).
Greetz,
MatchASM
Old 30th December 2010, 02:49 PM   #107
Default Amended photo
Hi everyone, this an updated photo of the PCB. I have corrected some of the labels and added an idea for a modification.
Old 30th December 2010, 02:53 PM   #108
Default Amended parts list
Hopefully I have corrected my mistakes
1. Replace the output capacitors which are C1/C2 and C40/C41 on the balanced outputs, C293 and C299 on the unbalanced outputs. These are 470uF 16 V, non-polarised electrolytic Ė I used Michicon Muse ES. Or just short them out by turning the PCB over and soldering a thin wire across each capacitorís pins. However this DC couples the DACMagic output to the preamp or amp it is plugged into, so consider using a DC voltmeter first to measure the DC offsets on DACMagic and the input you are connecting into.
2. Replace the power supply capacitors for the op amps/analogue circuits. I used Panasonic FCís as follows:
a. C76, C77, C402, C403 are 1,000uF 50V
b. C414, C415 are 10uF 35V
c. C419 is 1,000uF 35V, I used 1,000uF 50V as 2a above
3. Replace the power supply capacitors for the DSP and DAC digital circuits. I used Rubycon ZAís and ZLGís:
a. C424, C425 and C89 are 2,200uF 25V Ė the first two need to be smaller e.g. ZLG to fit in
b. C87 is 1,000uF 25V, I used 1,000uF 50V as 2a above
c. C8, C10, C25, C26, C31, C35, C45, C130, C426, C431, C435 are 10uF 35V
d. C103 is 100uF 16V
4. Replace the decoupling capacitors around the two WM8740 DACís. I used Rubycon ZLGís:
a. C270, C275, C276 and C301, C303, C304 are all 10uF 35V
b. C271 and C302 are 47uF 35V Ė I used the DACMagic value and not the 10uF on the WM8740 datasheet
5. Replace the op amps, which are tiny surface mount SO8 packages and on very thin PCB tracks:
a. U55, U56, U59, U60 are NE5532D and can be upgraded to your preference (please see earlier postings about the THD) - I used 4562MAís
b. U57 and U61 are OP275GS which can be upgraded to 4562MA or your preferred op amps
I left C44, C400 and C401 in place. You can also leave C5 and C212 as they are just the mute/relay supply.
Old 30th December 2010, 03:04 PM   #109
Default Idea for modification
I donít use the USB input and could probably use a third 24/96 bit input on the DACMagic. The 16 bit USB suffers from jitter and would need a lot of work to approach the quality of the other 2 inputs. As an alternative why not split the optical and coax input for digital input 1, so optical 1 replaces the USB input? This gives an extra 24 bit input?
In theory (I haven't tried it myself!) the modification would be along the following lines. Cut the underside PCB track from U23 pin pin 8 to U7 pin 5. Cut the track joining optical 1ís R16/C201 to U7 pin 3, connect this to pin 5 instead. Then connect U7 pin 3 to ground. I think these changes separate OPT 1 and COAX 1 so both can be connected.
The photo I posted today shows the basic idea in red. Optical 1* replaces the USB input. If it works, the three switchable inputs become OPT1, COAX1, and OPT2 or COAX2 depending which is connected.
* I think the schematic labelling of inputs 1 and 2 may be the wrong way around. U5 is optical 2 and goes to U7's 1-IN2, similarly for coax in 2 going to 2-IN2.
Old 30th December 2010, 03:09 PM   #110
Greetz,
MatchASM
Thank you for a helpful and thorough answer. And good point about the part change counts!
Opening the new DacMagic????Hide this!Advertise here!
Dacmagic Mods Blue_Max Digital Line Level 55 27th February 2016 01:53 PM
Sony CD-X33ES CD Tray not opening-help? eldarvanyar Digital Source 7 14th January 2008 06:12 PM
Help! Cracks opening in my veneer suzyj Multi-Way 7 28th December 2006 05:42 AM
Cambridge Dacmagic 1 ManUtd Digital Source 1 6th October 2003 11:17 AM
Copyright ©1999-2019 diyAudio
