Construction Tips Construction techniques and tips
Run a ground wire, but not connect it?
Thread Tools
Old 24th October 2021, 01:56 AM   #1
SoaDMTGguy is offline SoaDMTGguy  United States
Learn, try, fail, learn
SoaDMTGguy's Avatar
Default Run a ground wire, but not connect it?
I'm working on a Hafler DH-110. This connection to the output connections board is wired as according to the manual. Two pairs of red and green wires with an associated ground wire. One ground is soldered to the board, the other is wrapped around its pair. Why run the second ground if it won't be connected? What benefit does this wiring scheme serve?
Old 24th October 2021, 02:00 AM   #2
rayma is online now rayma  United States
It acts as a shield, but avoids a ground loop.
Old 24th October 2021, 02:02 AM   #3
SoaDMTGguy's Avatar
That was my best guess, I’d just never seen it before. Nifty!
Old 24th October 2021, 03:29 AM   #4
Similar to when a shielded cable is used with the shield connected only at one end.
Old 24th October 2021, 06:16 PM   #5
Mark Tillotson is offline Mark Tillotson
I think the black wire is supposed to be connected on both. Looks like its been modified I'd expect the wiring to be screened (although not really needed for a low impedance output).
I'm assuming red and green are the two channels and black is the ground?
Is the ground on the connector PCB actually commoned for the top and bottom rows, its not clear from the photo?
Old 24th October 2021, 06:32 PM   #6
SoaDMTGguy's Avatar
Yeah, it’s a common ground. This is how it’s specified in the manual.
Old 24th October 2021, 07:09 PM   #7
All of Hafler's preamps have been connected in that way.
  Reply to this post
Run a ground wire, but not connect it?Hide this!Advertise here!
Thread Tools
Connect Virtual Ground to Real Ground amendiola Analogue Source 3 17th March 2015 04:08 PM
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 10:42 PM
Connecting amplifier chasis to earth ground, but not amplifier ground Fusion916 Solid State 3 5th March 2014 09:49 PM
To connect or not to connect.......... G Tubes / Valves 4 13th October 2011 09:55 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
