Construction Tips Construction techniques and tips
What glue for grille cloth to wood grille?
Thread Tools
Old 29th September 2021, 10:55 PM   #21
MAAC0 is offline MAAC0  Portugal
You could also try adhesive Velcro strips.
Old 30th September 2021, 12:57 PM   #22
dudaindc is offline dudaindc  United States
dudaindc's Avatar
Originally Posted by Galu View Post
This guy uses double sided sticky tape! How to replace OLD speaker grill cloth DIY - YouTube
Brilliant!
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 30th September 2021, 03:49 PM   #23
soundoutlad is offline soundoutlad  Ireland
If you're using a heavier covering like this;
Grill Cloth Wheat Basket :: Grill Cloth, Piping :: Grill cloth, Tolex and Piping :: Amp Parts :: Banzai Music GmbH
It might be a good idea to have plenty of strong clips;
Q Connect 51mm Grip Clip, Black (Pack of 10) : Amazon.co.uk: Stationery & Office Supplies
Old 30th September 2021, 03:59 PM   #24
Dave R is offline Dave R  United States
Dave R's Avatar
You could consider the use of a staple gun. That's how my grille cloth is held on.
+1
- Dave R
the 200% Norske
Old 24th November 2021, 10:46 AM   #25
Kevano is offline Kevano  India
Originally Posted by NareshBrd View Post
The adhesive dies out at the joint, I mean joints made with this adhesive fail after some years, if it is solvent based rubber or similar.
In India, of course.
Your mileage may vary.
Can Fevibond be used to stick polyester open weave grill cloth to MDF ?
Pidilite Fevibond for Sticking Leather Rubber Rexine (50ml) : Amazon.in: Industrial & Scientific
If not, what product is available in India ?
Old 24th November 2021, 12:18 PM   #26
NareshBrd is offline NareshBrd  India
Ask at hardware shop
SR998 is also made by them, comes in tins, and is intended for use by cobblers, carpenters and so on.
Much cheaper than tubes.
Try a small patch first.
Old 24th November 2021, 08:35 PM   #27
hpro is offline hpro  Switzerland
Originally Posted by Dave R View Post
+1
+2
Holds longer than everything else.
and if you work clean, it's hard to see..
BTW it's by Far the fastest way to do..
about 10 minutes for on speaker Cover *this if you have done it a few times.*
More you can line up the cloth very well and you will not see these ugly stripes when not pulled with the same strength on each side.
Old 24th November 2021, 10:10 PM   #28
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I gave up on staple guns. I have air staplers and it isn't as good as doing it with hot glue and a wood press in the method I described earlier. Try it once and chances are you'll put away the staple gun. You also never have to worry about staples pulling through or backing out, as they are prone do. Staples win when it comes to speed of assembly but lose when it comes to longevity.
Old Yesterday, 07:33 PM   #29
Galu is offline Galu  Scotland
The staples securing the grille fabric of my Mordaunt-Short MS100 speakers show no sign of giving up on the job after nearly 35 years of removing and refitting the grilles before and after critical listening.
You can just about see the staples in the attached stock image.
Then again, this is a factory manufactured speaker, not diy.
Old Yesterday, 08:35 PM   #30
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Your choice.
Pulling through is operator error, choosing too long ones, legs longer than base material thickness.
"Backing out": never ever seen in over 14000 cabinets along over 50 years.
If properly applied that is.
If anything, they are *hard* to remove when reclothing.
Does flawless 50 years performance count as longevity?
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
What glue for grille cloth to wood grille?Hide this!Advertise here!
Thread Tools
new grille cloth drakston Construction Tips 0 12th August 2018 10:03 PM
Grille cloth recommendations and fitting instructions? mr_push_pull Construction Tips 3 14th October 2014 03:15 AM
Mirage M1 grille cloth removal? RobL Multi-Way 5 26th February 2013 10:50 PM
Linn Kaber Keilidh Nexus Baffle Front Covers/Grille Cloth with Strap needed tiefbassuebertr Multi-Way 2 7th August 2011 01:34 PM
Advice needed re the effects of grille cloth Brisso57 Multi-Way 9 14th November 2010 03:41 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
