Construction Tips Construction techniques and tips
Phantom Power and Mic Capsule Voltage
Thread Tools
Old 9th June 2021, 03:34 AM   #21
sonnichs is offline sonnichs  United States
Thanks all for your interesting replies.
Rick-the underwater issue is not a problem here-in fact we have been doing this for years. But I need a quick and simple in-air equivalent mainly to test some processing code and mathematical issues. (no need for the water here which is expensive--besides -I get seasick!)
So this system would simulate some water issues in the code but the only concerns here are to get a set of small mics that I mount in my configurations working with a recorder (probably zoom) and also with our ADC system.
cheers
Fritz
Old 9th June 2021, 04:36 AM   #22
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Mark Tillotson View Post
....True condenser microphones will require a sufficiently high voltage, near 48V....
Some early P48 mikes used the 48V directly for polarization, as well as to drive the buffer.
Today most >$200 mikes (and some under) use DC-DC conversion to take a wide range of inputs. I know the AKG 414 very well, it would accept down to nominal 12V because internally it made regulated 9V for the buffer and jacked that up for the polarization.
"Headroom" is not an issue. The 414 can deliver an incredible (for a mike) 2V. So 9V supply is ample. Few mikes will deliver an honest 0.5V. Doesn't take much.
Old 9th June 2021, 04:39 AM   #23
MarcelvdG is offline MarcelvdG  Netherlands
What's this whole underwater thing meant for anyway?
Old 9th June 2021, 11:13 AM   #24
Thank you Paul. I am using only one brand of mic and one recorder or ADC circuit so I will not have to genericize the range of voltages received. I can pre-calculate it all. I large number of capsules listed have an input impedance of 2.2K and an acceptable voltage range of 2-10V so I just need to provide that. The only concern is being sure I don't overdrive the compliance of the recorder phantom power (or short it) as I obviously don't want to destroy it.
Marcel--underwater mics are used for various things in the oceanography field--visualization, listening to biota, detecting distances for submarines.
thanks
fritz
Old 10th June 2021, 12:32 AM   #25
Dave Zan is offline Dave Zan  Australia
Today most >$200 mikes (and some under) use DC-DC conversion...
What mics do this?
Apart from AKG there are only a few I know, the Josephson and Gefell MV225 both use measurement capsules as omnidirectional studio mics but are ~$2000.
All the other measurement mics need 200 V or use electrets and don't need any DC-DC conversion.
I assume there must be voice/studio mics that use DC-DC but I wouldn't have expected "most".
They still copy old Neumanns and haven't moved to electrets?
Maybe such a DC-DC mic could be adapted to drive a measurement capsule...hmm.
Best wishes
David
Old 10th June 2021, 02:35 AM   #26
PRR's Avatar
I thot we were talking P48 studio mikes? How did 200V system come in?
OK, I see your measurement mike thread. That's another world from P48. In studio you may have very long cables and you should not electrocute performers. In measurement, cables may be short (and unbalanced) and technicians should know better.
Old 10th June 2021, 08:33 AM   #27
..P48 studio mikes? How did 200V system come in?
These are P48 studio mics, they use DC-DC converters (to power the 200 V polarisation of the capsule), just as you said "most >$200 mikes" do.
Is this not exactly what you talked about?
My question is what other mics do this, the 200 V system is what I wish to avoid.
Best wishes
David
Old 10th June 2021, 07:25 PM   #28
PRR's Avatar
I'm sure you know more than me about these things.
  Reply to this post
Phantom Power and Mic Capsule VoltageHide this!Advertise here!
Thread Tools
Wanted: Panasonic capsule mic Spasticteapot Swap Meet 10 30th April 2021 10:54 PM
phantom voltage mic-preamp Marrrrris Analog Line Level 6 28th July 2020 01:09 PM
A/B Switch 2 mic pair in / 1 mic pair out (must carry phantom power mlynnh Analogue Source 5 16th February 2020 04:35 AM
Panasonic mic - guess the capsule...? Mos Fetish Multi-Way 4 11th September 2004 10:43 AM
phantom powering non-phantom mics karambos Instruments and Amps 8 3rd January 2004 09:21 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
