Construction Tips Construction techniques and tips
Building using solid wood
Thread Tools
Old 23rd April 2021, 12:28 AM   #51
Bendinggrass is offline Bendinggrass  Canada
Sorry, I can't say as I am not familiar with your terms.
I guess if you are in Canada and recognize the term, you are familiar with this stuff.
Do you think it could be good for making speakers, by gluing layers together to absorb vibrations?
Old 23rd April 2021, 02:10 AM   #52
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Many thin layers glued together is called plywood.
dane
Stay safe. Stay home. Respect the 2m bubble.
Old 23rd April 2021, 03:25 AM   #53
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
Check post #41 and search that term. It may well answer your question?
Old 23rd April 2021, 12:58 PM   #54
Thanks, yes, going through that thread.
I was thinking of masonite because it was (long ago?) fairly cheap,,,,, and I have been reading about multiple layers. I was thinking about the advantage of its flexibility, and the glue layers absorbing the acoustic energy. It might be less expensive than plywood from a layer /cost perspective. I don't know.... just exploring ideas here.
Thanks.
Old 1st May 2021, 12:54 PM   #55
Mark Tillotson is offline Mark Tillotson
Originally Posted by scottjoplin View Post
Deciduous trees are generally hardwood and conifers are generally softwood
Hardwood has ribs radiating out from the centre, softwood doesn't, Balsa is a hardwood despite not being hard, its all about the structure.
Technically hardwoods are dicot angiosperm species (roughly the same as deciduous), and softwoods are gymnosperm species. The variation in properties withing each category makes the distinction moot sometimes, but most hardwoods are dense and hard - hardwoods usually have more lignin too and are darker in colour as a result, sometimes very much so - lignin is much harder/stronger than celulose.
  Reply to this post
Building using solid woodHide this!Advertise here!
Thread Tools
A precautionary tale of building with solid wood. AJ Wykes Multi-Way 20 7th May 2021 10:35 PM
MDF vs solid wood polvoson Multi-Way 34 18th November 2016 12:28 AM
Effects of Solid Wood Hardness on Sound konut Multi-Way 5 8th September 2007 04:31 AM
Solid Wood Plinth jlsem Analogue Source 2 2nd August 2007 11:22 PM
using one piece of solid wood for an enclosure Jared Multi-Way 13 7th May 2003 11:45 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
